Go to Post I always say find what works best for your team, for your given situation. Why should we rely on someone else to tell me what will work best for our situation? - JVN [more]
Unread 19-01-2017, 11:34
PhilBot's Avatar
PhilBot PhilBot is online now
Get a life? This IS my life!
AKA: Phil Malone
FRC #1629 (GaCo: The Garrett Coalition)
PhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond repute
Dev environment setup question.
I used Java and eclipse last year, but after installing this year's software I don't see the Robot Project templates when I do a file/new/project wizard.
What step are these installed in? ie: what did I miss?
I am running the Eclipse Neon.2 Release (4.6.2)
Phil.
Phil Malone
Garrett Engineering And Robotics Society (GEARS) founder.
http://www.GEARSinc.org
FRC1629 Mentor, FTC2818 Coach, FTC4240 Mentor, FLL NeXTGEN Mentor
Unread 19-01-2017, 12:32
EmileH's Avatar
EmileH EmileH is offline
#dontbelarge
AKA: Emile Hamwey
FRC #1058 (The PVC Pirates) & SLFF (NE Way You Want It)
Rookie Year: 2011
EmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant futureEmileH has a brilliant future
Re: Dev environment setup question.
Did you install the WPI Eclipse Plugins that give you the libraries and the deploy tools, as well as the framework?
Steps here: Scroll down to Installing the development plugins
2016-present: High School Student, FRC 1058 PVC Pirates
Unread 19-01-2017, 18:48
PhilBot's Avatar
AKA: Phil Malone
That would be the problem.
Thanks
Phil Malone
