Go to Post Safe zones are for the weak. - ChristopherSD [more]
Unread 19-01-2017, 14:52
Owen Busler's Avatar
Owen Busler Owen Busler is offline
Build Captain
FRC #0303 (Test Team)
Team Role: Leadership
Rookie Year: 2014
Owen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant futureOwen Busler has a brilliant future
Gear Drive Question
Hello all, due to some size constraints these two Versa Planetary gearboxes need to be mounted in this awkward position. One is 1:100 and the other is 1:35 and the gears on them are 20:60. Does anyone see this as a problem? As long as the ratios end up the same I believe it should be fine. Thoughts?
https://drive.google.com/open?id=0B6...GgxZDUwS0p6RTA
2016: Deans List Semi-Finalist/MAR Mount Olive District Engineering Inspiration Award/Buckeye Regional Second Alliance Captain/MAR Montgomery District Event Imagery Award/MAR Championship Gracious Professionalism Award
2015: MAR Mount Olive District Chairman's Award/MAR North Brunswick District Winners/MAR Championship Finalists
2014: MAR Clifton District Chairman's Award/MAR Championship Regional Chairman's Award
Unread 19-01-2017, 14:55
jwfoss jwfoss is offline
Chasing Elegant Simplicity
AKA: Justin Foss
FRC #0558 (Elm City Robo Squad)
jwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond reputejwfoss has a reputation beyond repute
Re: Gear Drive Question
Why not run the dual motor input from VexPro or switch to a more powerful motor such as the 775pro?
You may also want to consider using belt or chain to transfer power, it may open up some better options for you.
2003-2006 | FRC 0176 | Aces High - Student
2007-2010 | FRC 0229 | Division by Zero - Mentor in Training
2011-2013 | FRC 2168 | Aluminum Falcons - Mechanical Mentor
2013-20xx | FRC 0558 | Elm City Robo Squad - Mechanical Mentor
Chris is me's Avatar
AKA: Pinecone
The ratios don't work out exactly for that setup - 35 times 3 is 105:1, not 100:1. It won't be the most efficient way to get power from both motors.
Is there any reason you can't use the 2 motor VP adapter here? This seems like the perfect application for it, and it would take up less space.
Alternately, could you make both gearboxes the same ratio, and use 40 tooth gears on each to mesh them together? It's the same center to center spacing but no weird ratio combinations.
You could also use a single 775Pro for almost as much power as 2 BAGs. Any number of other solutions seem more robust and reliable than this one.
--2016 Waterbury SFs (with 3314, 3719), RIDE #2 Seed / Winners (with 1058, 6153), Carver QFs (with 503, 359, 4607)
-- 2015 TVR Motorola Quality, FLR GM Industrial Design -- 2014 FLR Motorola Quality / SFs (with 341, 4930)
-- 2013 BAE Motorola Quality, WPI Regional #1 Seed / Delphi Excellence in Engineering / Finalists (with 20, 3182)
-- 2012 BAE Imagery / Finalists (with 1519, 885), CT Xerox Creativity / SFs (with 2168, 118)
Student: 1714 (2009) - 2009 MN 10K Lakes Regional Winners (with 2826, 2470)
Ty Tremblay's Avatar
Ty Tremblay Ty Tremblay is online now
Robotics Engineer
FRC #0319 (Big Bad Bob)
Ty Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond reputeTy Tremblay has a reputation beyond repute
35*3 = 105
It might be close enough for an FRC bot, but it's definitely not ideal.
Unread 19-01-2017, 14:56
Build Captain
Rookie Year: 2014
The added length sticks outside our frame perimeter. We want the added safety of being able to stall the motor for more than 1/4 of a second without it burning out.
Unread 19-01-2017, 15:01
Build Captain
Rookie Year: 2014
I misunderstood how the Dual motor input is assembled. It looks like it will fit! Thanks for getting me to double check that.
Unread 19-01-2017, 15:12
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp), FRC #1592 (Bionic Tigers)
Team Role: Tactician
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
I would run 2 40t gears and the same ratio on both if you are set on using bag motors. Also, in the 4 seconds it takes a 775pro to burn out, it should be possible to have a current monitoring program shut down that mechanism. Can you provide details on what mechanism this is driving? Without knowing the application its hard to determine the best solution.
Past teams:
1523 (2011-2014)
1065 (2014-2016)
3932 & 4592 (2016)
