Issue with the NavX Library
One of the students on our programming team is having trouble uploading code to the robot. In her build path is:
Sidenote: I had the same issue after upgrading on kickoff, but managed to fix it. I can't for the life of me remember how though. |
Re: Issue with the NavX Library
This year, you no longer have to change build.properties, so whatever changes or additions you made there you should undo. Instead, what you're supposed to do, is put those libraries (navx, talonSRX, or any other user library) into your C:\Users\(current user)\wpilib\user\java\lib folder, make sure to update your build path on Eclipse, and then restart Eclipse. You only have to do that with user libraries, so you don't have to do anything to your wpilib, networktables, opencv, or cscore libraries.
I put them in C:\Users\(current user)\wpilib\user\java\lib folder but then it gives me a big ! over the project folder and doesn't recognize the AHRS. Did I miss a step?
Please review the updated FRC RoboRIO Java Library Getting Started instructions, which provide details on configuring Eclipse. |
