Go to Post If you have to build the best robot to be inspired then we end up with one winning inspired team, and 999 losers. That is not the spirit of FIRST. - KenWittlief [more]
Unread 19-01-2017, 17:23
granjef3's Avatar
granjef3 granjef3 is offline
Code Ninja
AKA: Matt
FRC #2383 (Ninjineers)
Rookie Year: 2016
granjef3 is an unknown quantity at this point
Question New CANTalon MotionMagic control mode documentation?
At worlds in 2016, the CTRE booth had a demo utilizing a new control mode called "Motion Magic" on the Talon SRX to control a robotic arm.
Some functions relating to this control mode are present within the docs for the 2017 CTRE FRC library docs, however details as to the exact function of this new control mode are absent from the Talon SRX Software Reference Manual.
Is the new Motion Magic mode present in the 2017 v2.20 Talon SRX firmware, and is there any documentation on how it works, the algorithm it uses, etc?
2016 Galileo Division Semifinalists with 341 Miss Daisy, 3683 Team Dave, and 4525 Renaissance Robotics
Thanks to all of our past alliance members!
Unread 22-01-2017, 13:34
abcurrie abcurrie is offline
FRC #2619
abcurrie is an unknown quantity at this point
Re: CANTalon MotionMagic control mode
I just asked CTRE the same question and I am posting the response here for others:
There's a new manual version going out soon, but I can give you the basic information in the meantime.
Motion Magic is a new control mode for Talon SRX that provides the benefits of Motion Profiling without needing to generate the profile data. You use the MotionMagic control paramter when setting the Talon Control Mode.
The first step for Motion Magic is setting up your position PIDF values as normal (see the Soft. Ref. Manual). You then use two additional calls (setMotionMagicAcceleration(double) and setMotionMagicCruiseVelocity(double)) to set the desired acceleration and cruise velocity parameters.
Once this has been done, you can use set() calls as normal to set the position that Talon will move to, and the motion will follow a trapezoidal motion profile (as described in the motion profiling documentation).
That's it! It gives you flexibility to have all movements follow a trapezoidal motion profile without actually generating the profile points.
Let me know if you have any additional questions.
Regards,
Jacob Caporuscio
Software/Hardware Engineer
CTR Electronics
