Go to Post A robot that can't move isn't a robot. It's just furniture. - John Neun [more]
Unread 19-01-2017, 17:40
swolverines's Avatar
swolverines swolverines is offline
FRC #3839
swolverines is an unknown quantity at this point
LabView Joystick Help Needed
We are not great with LabView. Let's get that out of the way.
How do we change what the joysticks do? We used the base Arcade Drive and the code is working with our robot after we assigned the motors and PWMs. However, it's just forwards and backwards.
How do we make it so we can assign certain axis to do certain things?
Thanks in advance.
Unread 19-01-2017, 17:44
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: LabView Joystick Help Needed
Arcade (the default robot project) should allow you to turn as well.
Does the robot not turn if you lean the joystick to one side or the other?
Unread 22-01-2017, 20:13
mshafer1 mshafer1 is offline
Programming Mentor
AKA: Matthew Shafer
FRC #3937 (Breakaway)
mshafer1 is an unknown quantity at this point
If you're robot is only going forward and backward, it may be a mismatch between the physical system and how the motors are opened in Begin.vi (are there four motors?). If the problem persists, could you post screen shots of opening the motors in Begin.vi and what you have for setting them (in Teleop)?
Team 358 has posted a lot of example code on their website: http://www.team358.org/files/program...hp#ArcadeDrive
Please feel free to personal message or email me if you have any issues and want a quick reply.
