Go to Post Honesty and Integrity is the key to success. If I don't teach my team to be honest, I am a failure! - team4384 [more]
Go Back   Chief Delphi > Competition > Rules/Strategy > Scouting
  #16   Spotlight this post!
Unread 26-01-2017, 12:32
Trevor1523's Avatar
Trevor1523 Trevor1523 is offline
Meme Queen
FRC #1523 (MARS / 6685 RPBHSR)
Rookie Year: 2014
Trevor1523 is an unknown quantity at this point
Re: 2017 Proposed Scouting Methods
Originally Posted by Skyehawk View Post
To take your example to the extreme:
If I had a fuel cycle in which I shot 9 balls (my entire hopper) and made 8/9 of them in 10 seconds I would be ranked higher than a team the shoots 75 balls in 10 seconds and makes 50 of them? You need some way to bring your ratio (make %) onto a level basis for comparison.
Just some thoughts.
Well it wouldn't necessarily be that crazy. I think we both know that 75 balls in 10 seconds is quite optimistic. I would actually prefer the 50 over the 9, because it's more balls per second. But if it took a lot longer to score, and the robot misses a lot of shots then theoretically the robot is just sitting there and not scoring points. I would be looking for robots that are efficient. I think that makes sense.
2015 Orlando Regional Finalists
FRC Team 1523 [2014-xxxx]
FRC Team 6685 [2017]
  #17   Spotlight this post!
Unread 26-01-2017, 13:18
Skyehawk's Avatar
Skyehawk Skyehawk is offline
Nuts N' Bolts
AKA: Skye Leake
FRC #0876 (Thunder Robotics)
Rookie Year: 2011
Skyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to allSkyehawk is a name known to all
My point is (and maybe you know this) you don't know the average amount of fuel shot information with the % method you are proposing. I will be releasing what data we will be collecting for this year on Feb 7th. While shots made % is a category we are tracking it has two other data-points to make the % a usable (and therefor worthwhile) data-point to track.
Hypothetical data (assuming constant cycle time):
Team # | ~High % | ~Load Size
001 33 20
002 50 50
003 100 10
If you only have the first two columns (Team # and make%) how are you going to differentiate what teams score the most? You will need another way to bring the make% into focus. If teams always used the full extent of their hopper you could use the size of their hopper, but there will not always bee full hoppers. I recommend including a 1/3 full, 2/3 full, and 3/3 full option just to get an easy average of their match load size. Cross reference this with how large their hopper is (from pit scouting or careful observation) and BOOM you can calculate ~fuel pts./match.
My time in FIRST has made me a better person, frankly I don't know where I'd be without it.
2011 Lake Superior Regional Champs (Thanks 2512 & 3747)
2015 Central Illinois Regional Engineering Inspiration Award recipients
2016 Central Illinois Regional Champs (Thanks 2481 & 2220)
[IMG] code is Off
