Go to Post Seems decretive bumpers are the new rage now. I couldn't stand making them once, never mind twice. - Gregor [more]
Unread 20-01-2017, 22:53
FRC Team CC FRC Team CC is offline
FRC #6560 (Charging Champions)
Rookie Year: 2012
FRC Team CC is an unknown quantity at this point
Programming Bulletin 873M Ultrasonic Analog Sensor
Hey guys. We can't find any libraries or information on programming the Rockwell Automation Ultrasonic and Color mark sensor that was available through first choice.
(http://ab.rockwellautomation.com/Sen...sonic-Sensors).
Does anyone know anything?
Thanks!
Team 6560
The Charging Champions
FTC Team #8660
Facebook Page: https://www.facebook.com/chargingchampions
Follow us on Twitter: @FtcTeamCC
Google Plus: https://plus.google.com/112552147224383900922/posts
Youtube channel: https://www.youtube.com/channel/UCop...G3zsvQKCXF4ESQ
Blog: http://chargingchampionsblog.blogspot.com/
Unread 20-01-2017, 23:01
arichman1257's Avatar
arichman1257 arichman1257 is offline
VP, Control Systems Captain, Coach
AKA: Alan Richman
FRC #1257 (Parallel Universe)
Team Role: Electrical
Rookie Year: 2014
arichman1257 will become famous soon enougharichman1257 will become famous soon enough
Re: Programming Bulletin 873M Ultrasonic Analog Sensor
Your link doesn't work.
Are you talking about one or both of these sensors?
Ultrasonic Proximity Sensor: http://firstchoicebyandymark.com/fc17-141
Photoelectric Sensor: http://firstchoicebyandymark.com/fc17-143
These are the two Rockwell Automation sensors on FIRST Choice
1257 Parallel Universe: 2014 - 2017 Seasons
2017: Vice President, Control Systems Captain, Drive Coach
2016: Control Systems Captain, Operator. MAR District Championship Winner, MAR Mt. Olive Event Winner, MAR Bridgewater-Raritan Event Finalist
2015: Control Systems, Operator. MAR North Brunswick Event Finalist
2014: Programming/Electronics Apprentice. MAR Clifton Event Winner
Unread 20-01-2017, 23:12
Rookie Year: 2012
Yes! sorry about that. Your links are correct. Do you know how to program it?
FTC Team #8660
Unread 20-01-2017, 23:22
AKA: Alan Richman
Rookie Year: 2014
Unfortunately I do not. We are getting the ultra sonic ones from FC I'm pretty sure. Once we figure it out I'll post something here. From what I've read about these they both have analog outputs so they will both connect to the analog in pins on the roboRIO. Presumably you can declare them in the code like any other analog input device.
In the mean time I'm also hoping someone posts on here what they've found.
Unread 20-01-2017, 23:27
Rookie Year: 2012
Ok thanks
FTC Team #8660
Unread 20-01-2017, 23:54
efoote868 efoote868 is offline
foote stepped in
AKA: E. Foote
FRC #0868
efoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond repute
I'm a little surprised that anything Rockwell doesn't have a 300 page manual associated with it...
Anyhow, if you click the ultrasonic sensor link on AndyMark's website, you'll be taken to the sensor page:
http://www.ab.com/en/epub/catalogs/1...Selection.html
Which your sensor shows: Analog voltage 15…30V DC 0…10V DC 873M-D18AV300-D4
Need to give it 15-30VDC, and the output will be analog, from 0-10V DC. Since the roborio's analog in looks like it only supports 0-5V, you'll need to attenuate the voltage (figure out a way to safely scale the 0-10V to 0-5V) otherwise you'll risk frying the analog in ports.
Let me know if any of that makes sense, or if you need help with the circuit.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
Unread 20-01-2017, 23:57
AKA: Alan Richman
Rookie Year: 2014
You could create a voltage divider using a few resistors.
Here's an article: https://learn.sparkfun.com/tutorials/voltage-dividers
Unread 22-01-2017, 12:18
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
We tried a voltage divider yesterday and was not able to get it to work. We only tried some resistors we had on hand... 4.7kOhm.
Our intent was to place two resistors in series, between the sensor signal, and ground, then wire the roborio signal from the common point between the resistors and ground.
All resistors we found when wired between the sensor output and ground the sensor went into an error state, and flashed red.
Was going to post our experiences today, but saw this thread. Please let me know if anyone else has success with a simple voltage divider, and what resistor values worked, pretty please.
The sooner we get behind schedule, the more time we have to catch up.
Unread 22-01-2017, 12:50
foote stepped in
AKA: E. Foote
FRC #0868
Were you able to read any voltage from the sensor? Do you have a voltmeter to debug the circuit?
On the introduction page:
http://www.ab.com/en/epub/catalogs/1...roduction.html
The red LED only flashes in teach mode, otherwise it is off. What were you doing with the white wire?
Unread 22-01-2017, 12:58
Rookie Year: 2012
We are using the 12v, 2 amp output on the VRM and a step up converter to amplify the voltage to 15v to power the ultrasonic sensor. We are yet to test it but we will reply with the results.
FTC Team #8660
Unread 22-01-2017, 13:01
Rookie Year: 2012
Now we have to figure out how to decrease the output voltage of the sensor so the RoboRio can process it.
FTC Team #8660
Unread 22-01-2017, 13:40
tr6scott's Avatar
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
We tested it wrong, now that I see the wiring diagram. We thought the white was the common for the analog output. We wired the resistors between white and black, now I see we should have done, black and blue.
Will test again on Monday and Post results, and what values of resistors we used for divider.
Unread 22-01-2017, 21:24
foote stepped in
AKA: E. Foote
FRC #0868
arichman1257 provided a simple solution:
Depending on the location of your roborio and the location of the sensor, you may consider an I2C or SPI analog to digital converter (ADC) chip and creating a custom circuit solution. Analog signals and distances don't mix very well.
Let me know if you need help with this.
Unread 24-01-2017, 07:32
tr6scott's Avatar
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
FWIW we tested yesterday with two 10k Ohm resistors wired in series between the black output and the blue 0V reference, and the sensor worked fine. The junction point between the two resistors ranged from 0-5v based on sensor distance, this test was done with a 24vdc power supply and a digital voltmeter, we did not install on bot yet.
Upon a more significant review of the data sheet, there is a small note that the the analog voltage sensors require input voltage of 15v-30v, which makes using this sensor on a robot more problematic, as you don't have easy access to voltages above 12v with the current control system provided.
We will be looking at a different solution to measure distance on the bot this year.
  #15   Spotlight this post!
Unread 24-01-2017, 08:42
foote stepped in
AKA: E. Foote
FRC #0868
Thanks for sharing your results!
This sensor is something I'd expect to find in a factory, wired to a relatively common 24vdc supply, not on a competition robot. It probably retails for way more than anyone would imagine.
