Go to Post My experience in FIRST has taught me that, whatever you do, make sure that no single failure can eliminate half your drive system.[...] The worst feeling in the world is having your robot driving around in circles when there is critical business to be done on the playing field. - Andrew [more]
Unread 21-01-2017, 16:13
abigailthefox's Avatar
abigailthefox abigailthefox is offline
FRC #1711 (Raptors)
Rookie Year: 2015
abigailthefox has a spectacular aura aboutabigailthefox has a spectacular aura about
OpenCV WPI Build Failure
I am working on installing this build of OpenCV, provided by WPI/FRC. I am doing this on a Windows laptop.
On the releases page, a JAR download is available, I downloaded this and tried to run it. It didn't run, and therefore I have done a number of things to try and resolve this issue.
1. I downloaded and installed the latest version of the JRE
2. I set the JAVA_HOME variable
3. Task Manager showed that Java was briefly being started up when I clicked on the JAR, but then immediately failing
4. I opened up the Java preferences in the Control Panel, set up the newest runtime, and then disabled the old one
5. The command line showed that the correct version of Java (with the correct path) was now running
6. When I tried to run the JAR from the command line, it gave me this error message
Code:
Exception in thread "main" org.apache.commons.cli.MissingOptionException: -v <version>
        at edu.wpi.first.wpilib.opencv.installer.MainCLI.main(MainCLI.java:70)
7. I then ran it with -v, to try and show what went wrong, and it gave me this error message
Code:
Exception in thread "main" org.apache.commons.cli.MissingArgumentException: Missing argument for option: v
        at org.apache.commons.cli.DefaultParser.checkRequiredArgs(DefaultParser.
java:211)
        at org.apache.commons.cli.DefaultParser.parse(DefaultParser.java:125)
        at org.apache.commons.cli.DefaultParser.parse(DefaultParser.java:76)
        at org.apache.commons.cli.DefaultParser.parse(DefaultParser.java:60)
        at edu.wpi.first.wpilib.opencv.installer.MainCLI.main(MainCLI.java:63)
Has anyone else had this issue, or does anyone have any suggestions for how to proceed?
Unread 21-01-2017, 16:35
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Re: OpenCV WPI Build Failure
I suggest you read the README.
And depending on what platform you want OpenCV for, you could just download it directly from the maven server
WPILib
GRIP, RobotBuilder
