Go to Post Is it legal to build 2 robots? yes. Is it crazy to do so? maybe. - Andy Baker [more]
Unread 21-01-2017, 17:11
dmelcer9 dmelcer9 is offline
AKA: Daniel
FRC #0810 (Mechanical Bulls)
Team Role: Leadership
Rookie Year: 2012
dmelcer9 is an unknown quantity at this point
URL for MjpegServer from CameraServer/USB Camera
I'm looking to use a USB camera connected to the robot for GRIP development. I know that GRIP doesn't accept the dashboard stream, but the MJPG stream supposedly works. However, I can't figure out what URL to point GRIP to if I want to actually use the stream.
Currently, our code looks something like this (forgot to commit to github so don't have the exact code):
Code:
//Robot.java -> RobotInit
UsbCamera c = CameraServer.getInstance().startAutomaticCapture();
MjpegServer s = CameraServer.getInstance().addServer("gripStream");
s.setSource(c);
What URL would I point the "Add IP Camera" source to in GRIP to get the camera to work properly?
Unread 22-01-2017, 00:07
Thad House Thad House is online now
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
Re: URL for MjpegServer from CameraServer/USB Camera
Code:
s.setSource(c);
You actually don't need that MjpegServer definition or the setSource line. startAutomaticCapture will automatically create the stream.
The way to access the code from GRIP would be
Code:
http://roborio-TEAM-frc.local:1181/?action=stream
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 22-01-2017, 00:18
AKA: Daniel
Rookie Year: 2012
Really? Thank you! I'm guessing any additional streams (for example if we have 2 cameras) would use port 1182? I saw some sort of reference to using the next available port.
Unread 22-01-2017, 01:38
Rookie Year: 2010
Yeah any additional cameras will just increase the port number, so cam 2 will use 1182, cam 3 will use 1183 etc...
Unread 24-01-2017, 22:01
AKA: Daniel
Rookie Year: 2012
Thanks! Didn't get a chance to test until today (building was closed for bad weather) but it worked really nicely. One (hopefully) last question: is there any way to increase the resolution of the mjpg stream? Currently GRIP shows the stream as a tiny thumbnail which is workable but a little annoying.
Unread 24-01-2017, 22:39
Rookie Year: 2010
When you call startAutomaticCapture, it will return a UsbCamera object. Call setResolution on that object, and that will set the resolution to whatever you put in.
Unread 24-01-2017, 22:41
AKA: Daniel
Rookie Year: 2012
Thanks! Didn't know that the USBCamera object affected the stream like that. Good to know.
Unread 25-01-2017, 07:40
ryan.mitchell ryan.mitchell is offline
FRC #1512 (Big Red)
Rookie Year: 2015
ryan.mitchell is an unknown quantity at this point
What would the mjpegserver be if I am accessing the camera from a raspberry pi? Currently I am just typing raspberrypi.local:1185 into a browser to see the camera image but I would like to get it to appear on my smartdashboard.
Unread 25-01-2017, 08:29
FRC #1512 (Big Red)
Rookie Year: 2015
Oh wait...it should be the same thing just port 1185, I'll give that a go and relay how it goes.
Unread 01-02-2017, 21:50
thecoopster20 thecoopster20 is offline
4th Year Programmer - Java
FRC #3602 (Robomos)
Rookie Year: 2014
thecoopster20 is an unknown quantity at this point
Any success? I am on the same boat as you are currently.
Unread 01-02-2017, 22:34
MuskieProgramme MuskieProgramme is offline
FRC #6420
Rookie Year: 2014
MuskieProgramme is an unknown quantity at this point
I would also like to know how to get the camera stream from the raspberry pi on the dashboard. Even better would be an unmodified Labview Dashboard, as nobody on my team is interested in using the other options. I'm fairly certain it is possible with the right things published to network tables, but who knows...
Unread 01-02-2017, 23:12
FRC #1512 (Big Red)
Rookie Year: 2015
Well, I'm upset...I hit submit post and it just went *poof*...anyway a rundown of my current situation is that it didn't work however I an idea that I just thought of which I will test tomorrow (and paste my code). I believe I have just been making a stupid mistake. As for MuskieProgrammes question, I would use the SmartDashboard definitely because I believe LabView can only handle Usbcameras, could be wrong though. Also, network tables can only publish/get variables (again, 99% positive).
Ryan
