Go to Post So take it all with a grain of salt, form your own opinions, lead by example, act responsibly, be graciously professional, and everything will be ok. - LauraN [more]
Unread 21-01-2017, 19:09
RaymondHeay RaymondHeay is offline
FRC #2656
RaymondHeay is an unknown quantity at this point
NavX Include Error
So, our team tried to download our code for the first *pun not intended* time this afternoon. In the course of this, we encountered an error with the NavX Library. During a normal debug build, we get no errors, and the library include paths are recognized. In the build stage after selecting the deploy option, however, somehow the library is no longer recognized, causing the build to fail. Going into the Properties of the project afterwords reveals that the library is no longer recognized.
This problem is present in this year's code, last year's code (not a problem before the updates), and in a bare-bones, example project with the only changes being adding the path (in theory), including the header file, and creating an object. It is the same in all three instances. Any feedback is appreciated, and thanks ahead of time for your help to get my team to take flight!
Unread 21-01-2017, 22:54
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: NavX Include Error
Could you post screenshots/full error details?
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 22-01-2017, 16:07
whitetail's Avatar
whitetail whitetail is offline
FRC #5407 (Wolf Pack)
Team Role: Driver
Rookie Year: 2014
whitetail is an unknown quantity at this point
I had a similar problem when using the Navx for the first time. Link:
http://www.pdocs.kauailabs.com/navx-...o-libraries/c/
Follow all the steps in the link and it should work. Pay special attention to where you put the file downloaded. Hopes this solves your problem. I am programming in java so it might be a different issue for you but it sounds similar to mine.
FRC Team 5407 -Driver, Programmer and Head Control Systems Engineer
2015 MAR Championship Rookie All Star Award
2015 MAR Hatboro-Horsham District Rookie All Star Award
2015 MAR Hatboro-Horsham District event Winner(Thanks 2590 and 2607)
2016 MAR Hatboro-Horsham District event Winner(Thanks 2607 and 1218)
Unread 23-01-2017, 14:13
WilliamFRC4065's Avatar
WilliamFRC4065 WilliamFRC4065 is offline
FRC #4065 (The Nerds of Prey)
Rookie Year: 2016
WilliamFRC4065 is an unknown quantity at this point
I would think that would help us understand your situation a lot better, the only thing I can think of without seeing the error messages is that your NavX libraries did not install correctly.
