Go to Post The kick-off is your opportunity to finally open the REALLY BIG box that has been sitting under the tree. - dlavery [more]
Unread 22-01-2017, 13:30
TBrient TBrient is offline
FRC #5735
TBrient is an unknown quantity at this point
Attempting to run a vision processing test results in library errors
I just created a GripPipeline file and put it into my eclipse project. When attempting to run a testing file (See below) I get the error "Exception in thread "main" java.lang.UsatisfiedLinkError: no cscore in java.library.path."
I have added all the WPILib libraries (including cscore) to my project's libraries list, and I have no clue what is wrong with the code.
Any suggestions?
My Test method:
public static void main(String args[]) {
UsbCamera camera = CameraServer.getInstance().startAutomaticCapture() ;
camera.setResolution(IMG_WIDTH, IMG_HEIGHT);
visionThread = new VisionThread(camera, new GripPipeline(), pipeline -> {
if (!pipeline.findContoursOutput().isEmpty()) {
Rect largestRectangle = Imgproc.boundingRect(pipeline.findContoursOutput() .get(0));
for (int i = 1; i < pipeline.findContoursOutput().size(); i++) {
Rect testRec = Imgproc.boundingRect(pipeline.findContoursOutput() .get(i));
if (largestRectangle.area() < testRec.area()) {
largestRectangle = testRec;
synchronized (imgLock) {
centerX = largestRectangle.x + (largestRectangle.width / 2);
System.out.println(centerX);
visionThread.start();
Unread 22-01-2017, 15:40
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Attempting to run a vision processing test results in library errors
Make sure you're using the correct cscore build (eg windows, linux, arm-raspbian, etc)
If it still doesn't work, go into the cscore jar and pull out the dll/so/etc for your architecture. In Eclipse, edit the build path item for cscore and for "Native library location" point to the folder where you put the library file.
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 22-01-2017, 19:48
wharrier2450 wharrier2450 is offline
FRC #2450
wharrier2450 is an unknown quantity at this point
Make sure you configure the native location properly. When I configured this the first time, I thought I did that but when I looked at the native path on the build path for my project it was not there. I added it to the User Library, removed it from my project, re-added it and it started working.
http://docs.opencv.org/2.4/doc/tutor...l#java-eclipse
Good luck
