Go to Post Being professional means doing things right. Being gracious means doing the right thing. They complement each other perfectly. But I think we should remember to use GP as a guide for our own behavior, not as a yardstick to measure others' shortcomings. - Alan Anderson [more]
Unread 22-01-2017, 16:52
NicholasJJ NicholasJJ is offline
FRC #4014
NicholasJJ is an unknown quantity at this point
Building FRC Gazebo Plugins for Mac OSX causing problems
I'm trying to set up gazebo on my mac using this guide: http://wpilib.screenstepslive.com/s/...nually-mac-osx But whenever I get to the
Code:
./gradlew -PmakeSim frc_gazebo_plugins
step I get this error message:
Code:
2 errors generated.
make[3]: *** [simulation/frc_gazebo_plugins/CMakeFiles/limit_switch.dir/limit_switch/src/external_limit_switch.cpp.o] Error 1
make[2]: *** [simulation/frc_gazebo_plugins/CMakeFiles/limit_switch.dir/all] Error 2
make[1]: *** [simulation/frc_gazebo_plugins/CMakeFiles/frc_gazebo_plugins.dir/rule] Error 2
make: *** [frc_gazebo_plugins] Error 2
:wpilibc:frc_gazebo_plugins FAILED
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':wpilibc:frc_gazebo_plugins'.
> Process 'command 'make'' finished with non-zero exit value 2
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
BUILD FAILED
Does anyone have any Ideas?
Unread 23-01-2017, 06:55
boz's Avatar
boz boz is offline
FRC #4014
boz is an unknown quantity at this point
Re: Building FRC Gazebo Plugins for Mac OSX causing problems
There's a bug report on the homebred-simulation GitHub repo about this. https://github.com/osrf/homebrew-simulation/issues/158
