Go to Post I am used to politicians getting up and being blowhards. - Steve W [more]
Unread 22-01-2017, 19:45
Robochris Robochris is offline
FRC #6722
Robochris is an unknown quantity at this point
CIM coders help!
Im having trouble programming the CIMcoders. Please correct me if you see something wrong im new at this.
So I have the Encoder plugged into the DIO on the roboRIO. From left to right on the encoder when placed on a motor, I have the 1st pin in DIO 0: 5V, 2nd pin in DIO 1: signal, 3rd pin in DIO 0: GRN, 4th pin in DIO 0: signal.
On the code side I am using C++. The Encoder stuff is inside a command and none of it is in the Robot.cpp or the main one. The "DriveCommand" is an Autonmous btw, not sure if that helps. When ever i run it in the FRC Drive Station, I get these errors. Need anymore information fill free to let me know. Thanks
ERROR -1029 HAL: Resource already allocated, Minimum Value: 0, Maximum Value: 20, Requested Value: 0 PWM [PWM.cpp:43]
ERROR -1029 HAL: Resource already allocated, Minimum Value: 0, Maximum Value: 20, Requested Value: 1 PWM [PWM.cpp:43]
ERROR -1029 HAL: Resource already allocated, Minimum Value: 0, Maximum Value: 31, Requested Value: 0 DigitalInput [DigitalInput.cpp:43]
ERROR -1029 HAL: Resource already allocated, Minimum Value: 0, Maximum Value: 31, Requested Value: 1 DigitalInput [DigitalInput.cpp:43]
ERROR -1098 HAL: A handle parameter was passed incorrectly InitEncoder [Encoder.cpp:43]
Them sick codez
Code:
#include "DriveCommand.h"
#include "WPILib.h"
#include "CANTalon.h"
using namespace frc;
bool done = false;
Victor *victor;
CANTalon *talon;
Victor *victor2;
CANTalon *talon2;
Encoder *CIM;
DriveCommand::DriveCommand() {
	victor = new Victor(0);
	victor2 = new Victor(1);
	talon = new CANTalon(1);
	talon2 = new CANTalon(2);
	CIM = new Encoder(0, 1, false, Encoder::EncodingType::k4X);
void DriveCommand::Initialize() {
void DriveCommand::Execute() {
	if (!done) {
		victor->Set(CIM->Get() > 5 ? 0 : 1);
		done=true;
execute()
bool DriveCommand::IsFinished() {
	return done;
void DriveCommand::End() {
	victor->Set(0);
	talon->Set(0);
void DriveCommand::Interrupted() {
Thanks for your help!
