You may possess me without penalty.
Unread 23-01-2017, 10:29
paul.dornfeld paul.dornfeld is offline
FRC #5523
paul.dornfeld is an unknown quantity at this point
Gears: Preloaded in Auton vs Three at Return Loading Station
If each bot preloads one gear each for auton, are there still three to play from the "return loading station" on your own alliance wall once teleop begins?
Unread 23-01-2017, 10:47
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Re: Gears: Preloaded in Auton vs Three at Return Loading Station
No, I don't think there are ever any staged there before the match. From section 4.2:
GEARS
D. One (1) available to each team to preload in their ROBOT (any not preloaded are staged with GEARS in E)
E. Eighteen (18) in each LOADING LANE (staged on the carpet between the LOADING STATION and the STARTING LINE)
F. One (1) in each AIRSHIP
The LOADING LANE for your alliance is on the opposite side of the field.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 23-01-2017, 10:51
Kevin Leonard Kevin Leonard is offline
Professional Stat Padder
FRC #5254 (HYPE), FRC #20 (The Rocketeers)
Rookie Year: 2011
Kevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond reputeKevin Leonard has a reputation beyond repute
We also had this confusion because of the way one of the maps showing yellow boxes with gear starting locations is drawn.
No gears start behind your alliance wall for your alliance. Those "3 Gears, 30 fuel" is the starting gears and fuel for autonomous.
All of my posts are my opinion only and do not reflect the views of my associated teams.
College Student Mentor on Team 5254, HYPE - Helping Youth Pursue Excellence
(2015-Present)
Alumni of Team 20, The Rocketeers (2011-2014)
I'm attempting a robotics blog. Check it out at RocketHypeRobotics.wordpress.com Updated 10/26/16
Unread 23-01-2017, 11:05
FRC #5523
Thank you, both.
