Go to Post "Professionalism at all times... even when you're playing an epic prank on your friends." - JVN [more]
Unread 23-01-2017, 12:43
rockinthespecs's Avatar
rockinthespecs rockinthespecs is offline
AKA: Kaitlyn
FRC #2067 (Apple Pi)
Team Role: Tactician
Rookie Year: 2016
rockinthespecs is an unknown quantity at this point
Pixy LabVIEW and I2C
Hi Everyone!
Our team bought a pixyCam this year to try out and see if it is easier to use than the kangaroo set up.
I was able to get my PixyCam up and running with PixyMon using this guide
I found some resources that explained the difference between plugging it into the analog X and analog Y port where you receive a voltage from the port and can program the robot accordingly, but only get either the x or y value.
I also learned that by plugging it into the I2C port, you can obtain both the x and y values. I found some examples of pixyCam and labview (pics attached) but I am not quite sure what data I am pulling from the camera and how to use it. I assume the 8 data points I am getting are the different objects I "taught" the pixyCam but I am not sure.
If anyone has any example code for the PixyCam with labVIEW or knows of a comprehensive guide that would be fantastic.
Thanks in advance!
ID:	21600  Click image for larger version
Unread 23-01-2017, 19:24
JamesBrown JamesBrown is offline
Back after 4 years off
FRC #5279
JamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond repute
Re: Pixy LabVIEW and I2C
This should give you some insight into the data you are getting. Check out the "Serial Protocol" section.
http://www.cmucam.org/projects/cmuca.../Porting_Guide
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
