Go to Post Have you ever found yourself staring at a physics problem, not understanding it, then connected it to a past FRC game and suddenly felt the light bulb start shining? - StephLee [more]
Unread 23-01-2017, 19:22
sabercatrobotic sabercatrobotic is offline
FRC #4146
sabercatrobotic is an unknown quantity at this point
Pixy connecting to roborio via usb
Our team has purchased a Pixy camera this year. We decided to try to use USB to communicate with the roborio. This has been the primary source we have been using.
http://cmucam.org/projects/cmucam5/w...ample_on_Linux
After getting through a wide range of problems, we are stuck so close to the end.
Code:
admin@roboRIO-4146-FRC:~/pixy/scripts# ./build_libpixyusb.sh
mkdir: can't create directory '../build': File exists
mkdir: can't create directory '../build/libpixyusb': File exists
-- Found libusb-1.0:
--  - Includes: /usr/include/libusb-1.0
--  - Libraries: /lib/libusb-1.0.so
-- Boost version: 1.57.0
-- Found the following Boost libraries:
--   thread
--   system
-- Configuring done
-- Generating done
-- Build files have been written to: /home/admin/pixy/build/libpixyusb
--   thread
--   system
-- Configuring done
-- Generating done
make[2]: Warning: File 'CMakeFiles/pixyusb.dir/flags.make' has modification time 14999 s in the future
make[2]: warning:  Clock skew detected.  Your build may be incomplete.
[ 16%] Building CXX object CMakeFiles/pixyusb.dir/src/chirpreceiver.cpp.o
[ 33%] Building CXX object CMakeFiles/pixyusb.dir/src/pixyinterpreter.cpp.o
virtual memory exhausted: Cannot allocate memory
CMakeFiles/pixyusb.dir/build.make:77: recipe for target 'CMakeFiles/pixyusb.dir/src/pixyinterpreter.cpp.o' failed
make[2]: *** [CMakeFiles/pixyusb.dir/src/pixyinterpreter.cpp.o] Error 1
CMakeFiles/Makefile2:60: recipe for target 'CMakeFiles/pixyusb.dir/all' failed
make[1]: *** [CMakeFiles/pixyusb.dir/all] Error 2
Makefile:113: recipe for target 'all' failed
make: *** [all] Error 2
We have tried to make a swapfile, but whenever we try to enable we get this
Code:
admin@roboRIO-4146-FRC:~# swapon /swapfile1
swapon: /swapfile1: Invalid argument
We're kinda at our wits end. Does anybody have any ideas? If this doesnt end up working, we will probably switch to IC2 or SPI, but USB would be preferable.
Thanks!
Unread 23-01-2017, 19:29
DevOrc's Avatar
DevOrc DevOrc is offline
FRC #4283 (INSPIRE ROBOTICS)
Rookie Year: 2016
DevOrc is an unknown quantity at this point
Re: Pixy connecting to roborio via usb
We had this same problem. We ended up communicating with Arduino because of the libraries.
Unread 23-01-2017, 19:53
Hadi379's Avatar
Hadi379 Hadi379 is offline
FRC #0379
Hadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to beholdHadi379 is a splendid one to behold
There are other ways to connect the pixy to the roborio. Have you tried the serial (SPI, I2C)? Or the Analog/Digital connections?
Unread 27-01-2017, 21:28
loafdog loafdog is offline
AKA: Maciej
FRC #2876 (DevilBotz)
loafdog is on a distinguished road
You can't use usb to connect Pixy directly to roborio. See https://www.chiefdelphi.com/forums/s...d.php?t=153409
We ended up using I2C to connect Pixy to roborio. We can get data from Pixy, no idea what to do with it yet .
