Go to Post I'm not sure I like this: corn dogs, cheesecake and lard. - Tom Ore [more]
View Poll Results: What gets harder at Champs?
The 4-rotor bonus will be made harder. 59 36.20%
The full steam bonus will be made harder. 39 23.93%
Both will be made harder. 39 23.93%
Neither will be made harder. 26 15.95%
Voters: 163. You may not vote on this poll
Unread 23-01-2017, 20:37
Billfred's Avatar
Billfred Billfred is offline
What gets buffed or nerfed this year at DCMP/CMP?
Last year, we saw FIRST increase tower strength for Championship--the first time they've invoked their right to adjust the point values since that right was reserved in 2012.
With all the talk of how important gears are and how relatively weak fuel is, do you think one will get adjusted up or down at District Championships or the FIRST Championship? If so, by how much?
94 events (more than will fit in a ChiefDelphi signature), 14 seasons, over 61,000 miles, and still on a mission from Bob.
Unread 23-01-2017, 20:44
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
That was a short break
FRC #2826 (Wave Robotics)
EricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond repute
Re: What gets buffed or nerfed this year at DCMP/CMP?
I think the gear count will be increased because its worth more points in elims than the fuel.
2002-2005 Appleton East High School: Team 93
2005-2011 Michigan Technological University: Team 857
2012-Present Wave Robotics Team 2826
Unread 23-01-2017, 20:47
NShep98's Avatar
NShep98 NShep98 is offline
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Team Role: Mechanical
Rookie Year: 2015
NShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud of
I think both will be made harder. By the time DCMP and CMP roll around, teams will simply be good enough to be able to handle the increase on both accounts. With the tower strength increase in 2016, the upper levels of teams could still easily beat the threshold.
If I had to pick one to be increased more, I might say the gears. With the fuel, too much of an increase can render it less than valuable compared to the reward. With what seems like the majority of teams leaning toward gear robots, we will probably see some very strong gear alliances that will be more than capable of handling a max 3 gear increase.
FRC 2079 - 4H ALARM Robotics 2015 - 2017
FLL 2011, 2013
Unread 23-01-2017, 20:54
Andrew_L's Avatar
Andrew_L Andrew_L is offline
#DriveSwerveEveryDay
AKA: Drübr Inc.
FRC #1323 (Madtown Robotics) #971 (Spartan Robotics)
Rookie Year: 2011
Andrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant futureAndrew_L has a brilliant future
Reserve and pre-placed gears will not start on the tower.
Unread 23-01-2017, 21:02
Bob Steele's Avatar
Bob Steele Bob Steele is offline
Professional Steamacrit Hunter
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
My opinion is that as we progress through the season we will see that many successful playoff strategies will hinge on defending just the last 2 of the gears. If a team can make another team "waste" their time putting on 4 of the last six and then jump them defensively for the last two, they can put up their own points while none are being scored by the gear running team.
Because of this, I don't think the number of gears will change at CMP.
Just my opinion
it is easily worth 2 cents.... but not more.
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
Unread 23-01-2017, 21:05
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
By removing the three pre-installed gears and the reserve gear, the RP threshold can easily be increased to 16 gears. The fuel threshold can be changed arbitrarily. I expect the median robot at CMPs to be able to score 6 gears or 40kPa of fuel, so that the gears will probably be increased, and the fuel possibly increased. I find a reduction in either very unlikely.
Unread 23-01-2017, 21:07
carpedav000's Avatar
carpedav000 carpedav000 is offline
Studenting is hard, but worth it!
AKA: David Carpenter
no team (Jerry-Rigg school of DuctTapeology)
Rookie Year: 2010
carpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant futurecarpedav000 has a brilliant future
Just my opinion
^^this
I believe we will see the fuel bonus upped to 60 KPh by the time DCMP rolls around, maybe even 80
It isn't shiny enough.
Unread 24-01-2017, 07:55
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Gears won't be nerfed - it looks to me that you'd need 3 really solid gear placing robots to even have a chance of getting all 4 rotors spinning. Fuel is what will be nerfed - right now, the best hopper autos have a chance of getting the RP in auto
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 24-01-2017, 08:06
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
In a high level of play, a 2 rotor auto is almost unbeatable, Can they change this?
Unread 24-01-2017, 08:50
Rookie Year: 2010
This (IMO) isn't going to be a common occurance (kinda like having 2 robots cross and score high in auto last year), so it likely won't be nerfed.
Unread 24-01-2017, 08:55
FrisbeeFunTime FrisbeeFunTime is offline
FRC #1768
Rookie Year: 2015
FrisbeeFunTime is an unknown quantity at this point
Is it possible that they could raise the difficulty of some task just for Einstein field?
Unread 24-01-2017, 09:03
Billfred's Avatar
Since the pre-populated GEARs are only on Rotor 3 and Rotor 4...no, unless they invoked more of a right than they claimed at Kickoff.
They didn't raise this possibility in the manual at Kickoff, nor have they ever done this before. (Okay, Dave Verbrugge pranked the Einstein crowd in 2006...but that was a prank.)
Unread 24-01-2017, 09:06
Chris is me's Avatar
AKA: Pinecone
I don't expect gears to change for DCMP or CMP. 12 a match is harder than it sounds. Perhaps more in elims, if anything.
Fuel will remain undervalued but will probably stay the same. They can only change the threshold pressure, not how many points it is worth, and 40 kPa will be reasonably achievable at top level but not overwhelming. Only if 60 ball autons are a dime a dozen will that happen - and when has something like that ever been the case?
--2016 Waterbury SFs (with 3314, 3719), RIDE #2 Seed / Winners (with 1058, 6153), Carver QFs (with 503, 359, 4607)
-- 2015 TVR Motorola Quality, FLR GM Industrial Design -- 2014 FLR Motorola Quality / SFs (with 341, 4930)
-- 2013 BAE Motorola Quality, WPI Regional #1 Seed / Delphi Excellence in Engineering / Finalists (with 20, 3182)
-- 2012 BAE Imagery / Finalists (with 1519, 885), CT Xerox Creativity / SFs (with 2168, 118)
Student: 1714 (2009) - 2009 MN 10K Lakes Regional Winners (with 2826, 2470)
Unread 24-01-2017, 09:19
PayneTrain's Avatar
PayneTrain PayneTrain is offline
no
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
I agree with you. People forget that not all DCMPs (...And now... CMPs) are created equal. The only thing that I would put even odds on happening is the death of the gimme gear that sits in the tower by the time late April rolls around. Cycling gears will have some advantages disappear as the season progresses through its naturally evolving meta, limiting any perceived need for FIRST to recalibrate.
It would have been nice to have had the GDC leave the door open on recalibrating the kpa bonus in concert with its required threshold, bit I'm not a cop and can't tell people what to do.
  #15   Spotlight this post!
Unread 24-01-2017, 09:48
jijiglobe's Avatar
jijiglobe jijiglobe is offline
FRC #0694
jijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant futurejijiglobe has a brilliant future
This would probably be pointless. Most of the alliances on Einstein play on a similar level when all their robots are working. The changes would have to be tailored very carefully to ever have the bonus affect one alliance but not the other.
RoboRio
Rob/oRio
oRio
photo credits to Greg McKaskle
