Go to Post FRC is about giving students the best experience possible. - MikeE [more]
Unread 23-01-2017, 23:22
subho subho is offline
FRC #6518
Rookie Year: 2017
subho is an unknown quantity at this point
2017 MS LifeCam causing RoboRio to bootloop:
Hello:
When trying to plug in the USB camera (MS LifeCam HD) we found that is causing the RoboRio to boot-loop (RoboRio keeps rebooting ever 7-10 seconds) in the following manner:
- All LEDs go off - 0 second mark
- Power, Status and RSL go orange after a second
- Power turns green at about 3-4 second
- All lights go off in 2-3 more seconds and the loop restarts
Unplugging the camera stops the bootloop. Battery level is showing at 90% ~ 12.4V.
Firmware version: 3.0.0f0
Image version: FRC_roboRIO_2017_v8
We have not reimaged or updated firmware on the RoboRio - it has stock firmware that it shipped with. We are using LabView for programming, and the Rio has LabView Robot code installed (built and deployed to the robot from LabView).
I see some errors like the ones below in the systems log viewer web page on the Rio:
spidev spi1.0: buggy DT: spidev listed directly in DT
and
UBIFS assert failed in ubifs_set_page_dirty at 1419 (pid 1106)
Thanks in advance for any help/advice.
Unread 23-01-2017, 23:29
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Re: 2017 MS LifeCam causing RoboRio to bootloop:
Is it possible that the ports on your roborio have some metal in them, and when you plug in the usb its causing it to short the pins, or maybe the usb plug on the camera is "messed up" and causing the roborio to short.
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
Unread 23-01-2017, 23:43
FRC #6518
Rookie Year: 2017
The USB ports look clean - just to be sure, I cleaned the usb ports w/ compressed air from a can and tried again, no joy.
The camera works well enough when connected to my laptop, so doesnt look like the usb plug is messed up. Any other ideas?
Unread 23-01-2017, 23:55
FRC #6518
Rookie Year: 2017
Also - I plugged in a usb mouse receiver to see if the pins are shorted - the mouse receiver did not cause the bootloop. The RoboRio continued to work fine...
Unread 24-01-2017, 07:43
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Have you tried using a different lifecam?
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 24-01-2017, 08:46
FRC #6518
Rookie Year: 2017
Sorry - no. We are a rookie team, and don't have additional lifecams...
This lifecam seems to work okay with my laptop (windows 10 x64).
Unread 24-01-2017, 09:02
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
I suggest you invest in one of these. They are "only" 20 dollars, and are definetly known to work with the roborio (many, many teams use them).
Unread 24-01-2017, 11:09
Would it be possible to get details on the LifeCam that is causing the issue? Model number, picture, etc.
We try to test many cameras during dev and beta, and I have never seen or heard of this symptom. But if you give details, we will try to reproduce it.
Greg McKaskle
Unread 24-01-2017, 11:24
bobbysq bobbysq is offline
FRC #4646 (Team ASAP)
Rookie Year: 2015
bobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud ofbobbysq has much to be proud of
Have you tried plugging it in after booting the RoboRIO? If that works fine, you should check if the camera is noticed by the web config or by sshing into the RoboRIO and running
Code:
$ ls /dev/video*
Unread 25-01-2017, 00:08
FRC #6518
Rookie Year: 2017
Thanks so much for the response: I am working w/ NI to try and get this fixed. Will let you know how that turns out.
