Go to Post I love how these contests always seem to find their way to go back to Dave Lavery and (pick one) Krispy Kreme/Heidi/Photoshop - DCA Fan [more]
Unread 24-01-2017, 18:53
beijing_strbow beijing_strbow is offline
FRC #5968 (Cyborg Indians)
Rookie Year: 2016
beijing_strbow is an unknown quantity at this point
roboRIO Web Dashboard Doesn't Show Device Settings
When I try to connect to the web dashboard everything shows up fine. However, when I go to the device settings page and click on a device to change the settings, it says the device can't be found and to check whether it's connected to the network. It does this even for the roboRIO itself.
I'm using Internet Explorer, and "device settings" is checked as an enabled feature on the installed features page.
Any help would be much appreciated.
Unread 24-01-2017, 20:06
Tungrus Tungrus is offline
Tungrus is just really niceTungrus is just really niceTungrus is just really niceTungrus is just really nice
Re: roboRIO Web Dashboard Doesn't Show Device Settings
Just curious, did you login as admin? There is a login link on the top right corner.
Unread 24-01-2017, 20:10
Rookie Year: 2016
I tried logging in as admin already.
Unread 24-01-2017, 22:11
mshafer1 mshafer1 is offline
Programming Mentor
AKA: Matthew Shafer
FRC #3937 (Breakaway)
mshafer1 is an unknown quantity at this point
Is the roboRIO in safe mode? (status light blinks in sets of 3). If so, power cycle it (without touching the reset button on it) and that should fix it. If not, call the help line - 1 866 ASK MYNI (275 6964)
Unread 25-01-2017, 16:25
TylerHarmon's Avatar
TylerHarmon TylerHarmon is offline
Rookie Year: 2014
TylerHarmon is an unknown quantity at this point
If the device can't be found, it could be an electrical problem. Check the CAN wiring for all devices. If you can't see any devices, the beginning of the can bus could be damaged, so double check that the roboRIO is correctly sending CAN traffic.
