Go to Post If there's one bit of advice I can give, its never underestimate the power of a hurricane. - Joshua May [more]
Unread 24-01-2017, 22:25
MuskieProgramme MuskieProgramme is online now
FRC #6420
Rookie Year: 2014
MuskieProgramme is an unknown quantity at this point
Switching Camera Views
I would like to know if it is possible to change the current camera display programmatically. What I would like to achieve as the end result is having two cameras, one forward, one backward, that switch based on the direction the robot is currently moving (with a manual override).
I currently am able to manually change the view by selecting the desired view from the drop-down menu on the dashboard, and may display both simultaneously if I wish.
