Go to Post Robot teams will expand to fill the available space. - topgun [more]
Unread 25-01-2017, 01:27
balloman balloman is offline
Sophomore Programmer
AKA: Bernard
FRC #0034 (Rockets)
Rookie Year: 2016
balloman is on a distinguished road
C++ Network Tables
Ok, well I have recently been developing Network tables on our Nvidia Jetson, and have been testing out code in Windows using Visual Studio. Our only problem is that I can't seem to figure out how to get the .lib file so that I can compile and run in Visual Studio. It seemed to be in previous versions of the Network Tables library, but I don't know how to get it with the latest version. How can I do that?
Unread 25-01-2017, 02:00
Thad House Thad House is online now
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
Re: C++ Network Tables
Are you using VS 2013 or 2015? And are you locally building ntcore, or just downloading the artifacts from the WPILib Maven server?
If you are using the maven artifacts, for VS 2013, you need to use the artifacts in the desktop classifier. If using VS 2015, you need to use the Windows 2015 classifier. Also note you need to have wpiutil linked as well, as that is also a native dependency. Make sure the classifiers match between the 2.
If locally building ntcore, make sure you are linking to both ntcore and wpiutil. wpiutil is built at the same time as ntcore, and is in the arm/build/wpiutil folder after the gradle build occurs, instead of arm/build/ntcore.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
