Go to Post The biggest thing is you don't have to make your robot like another teams. Come up with something unique and go from there. RAISE THE BAR..... - camtunkpa [more]
Unread 25-01-2017, 08:02
MarlyM64 MarlyM64 is offline
FRC #1660 (Harlem Knights)
Rookie Year: 2016
MarlyM64 is an unknown quantity at this point
Need NetworkTables to update??(Grip)
How do I get the NetworkTables to update when the camera is plugged into the roboRio? (Grip related issue)
When the camera USB is plugged into the computer our networkTables update fine, and the GripPipeline code that Grip generated works fine, but we cannot get grip to publish networkTables that update when the camera is connected to the robot.
Unread 25-01-2017, 10:32
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Re: Need NetworkTables to update??(Grip)
GRIP only generates the vision processing code. You have to write the NetworkTables part.
If you take a look at this screensteps page, you can publish to NetworkTables inside the callback in the second code block. Something like
Code:
visionThread = new VisionThread(camera, new Pipeline(), pipeline -> {
  centerX = ...
  centerY = ...
  NetworkTables.getTable("vision").putNumber("centerX", centerX);
  NetworkTables.getTable("vision").putNumber("centerY", centerY);
We should also have an example for sending results to the SmartDashboard up in the next few days.
WPILib
GRIP, RobotBuilder
Unread 25-01-2017, 14:14
Rookie Year: 2016
yes i have code similar to i, but it still won't work ._.
visionThread = new VisionThread(camera, new GripPipeline(), pipeline -> {
if (!pipeline.filterContoursOutput().isEmpty()) {
System.out.println(pipeline.filterContoursOutput() .get(0));
//SmartDashboard.putNumber("opencv",pipeline.filterC ontoursOutput().get(0));
table = NetworkTable.getTable("GRIP/marly");
double[] def = new double[0];
double[] areas = table.getNumberArray("width", def);
System.out.println(areas[0]);
visionThread.start();
Unread 25-01-2017, 14:24
FRC #2084
You're doing vision processing, but not using the results. You need to be putting values into the table.
WPILib
GRIP, RobotBuilder
Unread 25-01-2017, 16:44
wlogeais wlogeais is offline
FRC #2177 (The Robettes)
Rookie Year: 2011
wlogeais is an unknown quantity at this point
Seems to me your goal is really how to 'get' and display?
Rect r = Imgproc.boundingRect(pipeline.filterContoursOutput ().get(0));
SmartDashboard.putString("opencv", "at (" + r.x + ',' + r.y + ')' );
