Go to Post This is how students can be inspired! - Rich Wong [more]
Unread 25-01-2017, 15:50
Team5709 Team5709 is offline
FRC #5709
Team5709 is an unknown quantity at this point
Encoder Help
Hello everyone! I was wondering how I would use encoders to figure out how far our robot would drive in autonomous? A big thanks in advance for those who are willing to help.
Unread 25-01-2017, 16:31
TylerHarmon's Avatar
TylerHarmon TylerHarmon is offline
Rookie Year: 2014
TylerHarmon is an unknown quantity at this point
Re: Encoder Help
You need to provide more information and be more specific. You should ask a question like this: "With a CANTalon SRX, how can I use a Hall Effect Two Channel Encoder (am-2816a) to read a velocity?"
You need to wire an encoder to your motor controller, and then read that encoder, usually from that motor controller.
Unread 25-01-2017, 17:04
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Encoder Help
With a general question, you get a general answer.
The encoder delivers a fixed and known number of pulses per revolution. If you have a 200 pulse-per-revolution encoder, for example, each time the shaft to which it is mounted turns one revolution, your RoboRIO will see 200 pulses.
If you then calculate how far your robot goes in one revolution - Pi is your friend here - you can then measure distance by counting pulses. This is known as Odometry.
Many encoders have a second "orthagonal" output, which can be used to determine the direction of rotation.
Also be aware that some encoders do not output pulses, but instead a variable voltage or some other 'thing' - and we're not discussing those kinds of encoders here.
Good luck!
Unread 25-01-2017, 17:20
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Encoder Help
Answer these questions and you may get more detailed help:
what is the part number of the encoders
how are the encoders wired [roboRio or SRX]
where are the encoders mounted
what is the gear ratio between encoder and wheel
what kind of drivetrain are you using
what is wheel diameter
what model motor controllers are you using
are you using PWM or CAN bus
Unread 25-01-2017, 17:32
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: Encoder Help
If you haven't made any of the decisions yet about what encoders to use and need help with THAT, knowing the specifics of your gearbox (make and model type stuff) as well as the other things Ether mentioned that you DO know will help in getting those answers.
Unread 25-01-2017, 19:02
Rookie Year: 2014
Re: Encoder Help
Exactly! This information is important to solving the problem that you have. Jumping headfirst into a problem like "How can I make the robot drive 5 feet with encoders" can be daunting, so you should break it down into simpler pieces first
Unread 30-01-2017, 09:07
FRC #5709
Re: Encoder Help
Encoder: Encoder Kit AMT103-V (fc17-033)
they will be wired into the RoboRio. They are mounted on the out put shaft of the drive gear boxes. one on the left and one on the right. There is no gear ratio because its on the out put shaft and not on the motor it self. We are gonna be using arcade drive. The wheels are the 6 inch wheels (http://www.andymark.com/HiGrip-Wheel...?1=1&CartID=0). The motor controllers we are using are the 2015 Talon KOP controllers and those are using PWM.
Unread 30-01-2017, 11:46
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Encoder Help
Check out the screensteps reference: http://wpilib.screenstepslive.com/s/...or-other-shaft
And check out how to configure your encoder's pulses per revolution on the datasheet, page 4 http://www.cui.com/product/resource/amt10.pdf
Keep "maximum rpm" in mind when choosing a value. Choose the highest number of ticks that fits your intended rpm for the best accuracy.
Then you can get distance like this
Code:
Encoder enc = // create encoder as per screensteps
int ticksPerRev = // what you set them to
double diameter = 6.0; // inches
double distancePerRev = diameter * Math.PI;
enc.setDistancePerPulse(distancePerRev / ticksPerRev);
// later
double currentDistance = enc.getDistance(); // in inches
Edit: I'm unfamiliar with the 2015 KOP, but if those are Talon SRX controllers, you're a lot better off using CAN than PWM, because you can connect the encoders directly to Talons for high rate PID control.
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
