Go to Post Luck *good or bad* and opportunity will always affect what happens to teams. - Brian C [more]
Unread 25-01-2017, 16:58
galaxygaleas galaxygaleas is offline
AKA: Jillian
FRC #3229 (Hawktimus Prime)
Rookie Year: 2015
galaxygaleas is an unknown quantity at this point
Arcade Drive Xbox Controller Drive Train
We have four talon motors, two on each side of the chassis and would like to code all movement to be on the left joystick of an Xbox Controller. We have been having issues and aren't really sure how to do so. Most posts and steps only account for two motors, not sure how to have arcade drive with four.
Unread 25-01-2017, 17:30
GeeTwo's Avatar
GeeTwo GeeTwo is online now
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Rookie Year: 2013
Re: Arcade Drive Xbox Controller Drive Train
Assuming you have a regular skid steer drive train with two motors on each gearbox, just duplicate all of the code for the existing motors and change the object names to the new controllers (e.g. by appending a 2 to the name). Then in the motor initialization code, make sure you change the addresses to the second talons on each side. If this isn't clear, post your code and we can be more specific. (There are so many variables of motor controller type, CAN vs PWM, etc.)
Unread 25-01-2017, 18:37
david.e.boles david.e.boles is offline
Bringer of Whales and Petunias
AKA: david476
FRC #5940 (BREAD)
Team Role: Leadership
Rookie Year: 2011
david.e.boles is on a distinguished road
The other option, assuming your ESC has it, is to use a follower mode (9.1). Any other help is really dependent on your code.
