Gyro Help
Hi,
My team and I are currently trying to program a field centric drive program with a gyro. We are having struggles with our ADIS 16448 gyro plugged into the custom electronics port. Has anyone successfully implemented the ADIS 16448 into their labview code? We have the example code but are not able to get values onto the dashboard. Any help is appreciated, Team 4506 |
Re: Gyro Help
If you are able to read gyro values with the example code, then there are a couple of tutorials that will help you get that data onto the dashboard. Look on the Tutorials tab of the LabVIEW Getting Started Window.
Tutorial 6 - Creating a Custom Dashboard Tutorial 7 - Integrating Examples into Robot Code Specifically, parts 2 and 3 of Tutorial 7 show how to send data to the dashboard and how to display data on the dashboard. |
Re: Gyro Help
Like Doug said, if you are able to read the gyro, getting it talking to the dashboard is pretty simple (although you have to build a custom dashboard - if you build and open your custom one before launching the driver station - on the same computer - it will use the one you made).
This tutorial: https://frclabviewtutorials.com/gyro/ shows how to use the Smart Dashboard vi's to send the Gyro data to the dashboard (and get it to display) - your code will be different in that you will be using the example code to read the gyro and open the Gyro instead. |
Re: Gyro Help
Hello, old friends. You have the library I got way back when, so use the context help to figure out what each VI does.
Also, how are you linking up the send and receive VIs in your code and dashboard? |
