Go to Post (puts on his asbestos underwear, because these threads always get heated) - Billfred [more]
Unread 25-01-2017, 17:14
mananb mananb is offline
FRC #0224
mananb is an unknown quantity at this point
USB Camera FPS low
My team is having an issue with the FPS on Microsoft Lifecam 3000. When we first start the robot, the fps is at 30. However, after running the code a few times, the fps drops down to around 7. We have tried all the standard stuff: rebooting, checking the code for objects that may not have been garbage collected, etc. but haven't been able to find a solution. We also don't know whether it is problem in the roboRIO, the RAM, the camera, or the network. Does anybody know a possible solution?
Thanks
Unread 25-01-2017, 17:54
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Re: USB Camera FPS low
So many questions need to be answered before we can point you in the right direction:
What language are you programming your robot in?
Are you processing images, or just displaying them?
If processing, how and where?
At what resolution are you acquiring images?
Do you have compression set, and if so, to what level?
Are you using bandwidth limiting on the radio?
Are you even using the radio?
There are more, but this is a start.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 27-01-2017, 14:08
FRC #0224
What language are you programming your robot?
We are programming in java
We are processing the images using GRIP. This is most likely the problem.
We are using 320 by 240
We don't have a compression set.
We are using the default settings, don't know if this has a bandwidth limit.
Yes.
We are programming in java.
Unread 27-01-2017, 14:38
RoboChair's Avatar
RoboChair RoboChair is offline
He who fixes with hammers #tsimfd
AKA: Devin Castellucci
FRC #1678 (Citrus Circuits and 5458 Digital Minds)
RoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond repute
That only equates to a frame "latency" of 143ms, if you are doing vision processing ask yourself if you really need more than that. Less frames means less that you have to process or transmit.
12 Years and counting! Over a third of my life has been spent with FRC.
