If a. Run motor
Hello,
I am fairly new to FRC and I am supposed to be the programmer for my team. I am currently working on a program that will run a motor controlled by PWM for two seconds, if the button A on a Xbox controller is pressed. I have read articles and forums that explain bits and pieces on how to do it, but I am having problems putting those pieces together into a working program. I learn best by example, so if somebody could give me an example of the code for this program, it would be greatly appreciated. |
Re: If a. Run motor
I would watch these videos about RobotBuilder. Pay close attention to the Claw subsystem.
https://www.youtube.com/watch?v=k7Pa...ObeKzp&index=1 |
Coming from a person who has scoured screen steps for the exact same thing...
(These are just examples) Code:
//First declare the joystick somewhere as a pointer frc::Joystick* controller; Code:
//Make a bool and assign it to the controllers button in Telop bool a; Code:
//Pretend 1 is A for now
a = controller->GetRawButton(1);
if(a){
motor1->Set(0.5);
Code:
//The bool goes into the robot init //The joystick definition goes in the private section of the robot class //And the code to execute it goes in telopPeriodic |
Re: If a. Run motor
Re: If a. Run motor
Thank you so much, this was very helpful.
