Go to Post So take it all with a grain of salt, form your own opinions, lead by example, act responsibly, be graciously professional, and everything will be ok. - LauraN [more]
Unread 26-01-2017, 17:35
rtse's Avatar
rtse rtse is offline
449 Lead Programmer
AKA: Ryan Tse
FRC #0449 (Blair Robot Project)
Rookie Year: 2016
rtse is an unknown quantity at this point
Deploying Problem liblog4cpp_gcc
I was trying to deploy my code and I got this error.
Code:
Exception in thread "main" java.lang.UnsatisfiedLinkError: /var/volatile/tmp/libwpilibJavaJNI6460090964424469265.so: liblog4cpp_gcc-4.4-arm_v2_3.so: cannot open shared object file: No such file or directory
When I deploy this version of the code, it deploys fine, however when I deploy this version, it doesn't work.
I have seen a similar "missing so file" error before, and I fixed it by reflashing the RoboRIO. However, reflashing the RoboRIO did not fix this error.
Has anyone experienced this before?
Ryan Tse
2015-2016: 449 Programmer
2016-2017: 449 Lead Programmer
GitHub
rytse@mbhs.edu
Unread 26-01-2017, 17:51
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Re: Deploying Problem liblog4cpp_gcc
Do you have the most recent Eclipse plugins installed?
WPILib
GRIP, RobotBuilder
