Go to Post I don't understand why it should matter if your robot is 100% student built, 100% engineer built or somewhere in between. As long as you are Inspired (I word again) FIRST is getting its point and primary goal across. - [more]
Unread 26-01-2017, 19:31
daoliverio daoliverio is offline
AKA: Dom
FRC #3484 (Short Curciut)
Team Role: CAD
Rookie Year: 2015
daoliverio is an unknown quantity at this point
Does Anyone Have a Urethane Welding Kit That We Could Use In Central Ohio?
Hello, I am on team 3484 out of Marysville, Ohio. I was wondering if anyone in the surrounding area has a urethane belt welding kit. If you have one that we could use I would greatly appreciate it!
Unread 26-01-2017, 19:33
Billfred's Avatar
Billfred Billfred is offline
Re: Does Anyone Have a Urethane Welding Kit That We Could Use In Central Ohio?
With a lighter and some care, you don't need a welding kit. Relevant reading, including the quoted bit:
https://www.chiefdelphi.com/forums/s...2&postcount=14
Really, the whole thread is worth your time: https://www.chiefdelphi.com/forums/s...hreadid=154267
94 events (more than will fit in a ChiefDelphi signature), 14 seasons, over 61,000 miles, and still on a mission from Bob.
Unread 26-01-2017, 19:48
Brandon_L Brandon_L is offline
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Rookie Year: 2007
Brandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond repute
there are plenty of alternatives, as Billfred mentioned you can use a lighter. I've had success personally with a heat gun in the past. Also, I've heard it helps if you cut them on an angle so you have more surface area on your weld.
FRC 2495 - Hamilton West Robotics [2007-2014] - whats a..."hive mind"?
FRC 3929 - Atomic Dragons [2012-2013]
FRC 2180 - Zero Gravity [2017-]
Just trying to collect all the possible team colors
Unread 26-01-2017, 19:56
Munchskull's Avatar
Munchskull Munchskull is offline
CAD Designer/ Electrical Consaltant
AKA: Anthony Cardinali
FRC #0997 (Spartan Robotics)
Team Role: CAD
Rookie Year: 2013
Munchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to beholdMunchskull is a splendid one to behold
Old soldering iron with a flatblade screwdriver for a tip works quite well.
“In theory, theory and practice are the same. In practice, they are not.” ― Anonymous
Anthony Cardinali
4th year of FRC
Class of 2017
Unread 26-01-2017, 19:59
RoboChair's Avatar
RoboChair RoboChair is offline
He who fixes with hammers #tsimfd
AKA: Devin Castellucci
FRC #1678 (Citrus Circuits and 5458 Digital Minds)
RoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond repute
Here you go
https://www.chiefdelphi.com/forums/s...2&postcount=10
12 Years and counting! Over a third of my life has been spent with FRC.
Unread 26-01-2017, 20:01
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
Use a hot plate or an old pan on a stove and put it on the highest setting. Way easier to handle and it doesn't burn and char the urethane.
2014-2015: FRC 865 Warp7 Team Captain
2016: FRC 865 Mentor
2017: Free Agent Mentor, Inspector
