Go to Post I think the best driver team of the post season would be Mike Wade and Pete Baltzell- because they have been driving that NASA field all over the Northeast so all of us can play.Thanks guys!! - Wayne C. [more]
Unread 26-01-2017, 21:48
sauhaarda sauhaarda is offline
FRC #3341
sauhaarda is an unknown quantity at this point
Climb Stopping Mechanism
What strategies are you using to stop climbing the rope after the button is pressed at the proper pressure? Are you planning on a manual stop? A pressure plate stop? A stop based on stall torque? It seems to me that there is a very small window to stop the robot from applying to much pressure on the plate. How are you teams trying to address this issue?
ollien ollien is offline
FRC #5202
ollien is just really niceollien is just really niceollien is just really niceollien is just really nice
Re: Climb Stopping Mechanism
Honestly the best option seems to be driver control. It's a huge light. If they can see the rope well enough to grab it, they can see the touchpad light.
Unread 26-01-2017, 21:52
Billfred's Avatar
Billfred Billfred is offline
I tend to agree with the conclusion, but I don't agree with the methodology given that one davit is on the far side of the airship from the alliance. That will require a pilot to spot, or some kind of smarts. I had it backwards.
94 events (more than will fit in a ChiefDelphi signature), 14 seasons, over 61,000 miles, and still on a mission from Bob.
Unread 26-01-2017, 21:59
beijing_strbow beijing_strbow is offline
FRC #5968 (Cyborg Indians)
Rookie Year: 2016
beijing_strbow is an unknown quantity at this point
Our plan so far is to use a gyro to detect when the robot is angled up at more than, say, 5 degrees. Then we'll use an encoder on our climber winch to find our height, and stop when we hit the pad. The issue we've come up with is that the rope won't always wrap in the same path, so the distance you climb on each revolution will vary slightly. We're planning on using a velcro strip though, so this shouldn't be too bad. If it does end up being intolerable, we'll probably put a limit switch on the front of the robot to detect when we hit the plate and use the encoder to then climb another inch or two.
Unread 26-01-2017, 22:04
NShep98's Avatar
NShep98 NShep98 is offline
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Team Role: Mechanical
Rookie Year: 2015
NShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud of
If I'm looking at the manual drawing correctly, one of the davits is directly facing the alliance, not away from it. The other two are on the sides adjacent to the ladder, which is on the far side of the airship.
FRC 2079 - 4H ALARM Robotics 2015 - 2017
FLL 2011, 2013
Unread 26-01-2017, 22:14
cmwilson13's Avatar
cmwilson13 cmwilson13 is offline
AKA: Christopher Wilson
cmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura about
There is a 1 second delay between triggering the plate and the light activating.
that is plenty of time to break components at stall or burn up motors.
i don't have any testing to support it but i assume that with the can talons it will be super easy to detect the current spike once you hit the plate and then shut down the motors. it appears like a simple solution to me until testing proves otherwise
"Like the WWF, but for smart people." -George HW Bush
Team Member 1771 2008-2009
Team Mentor 1771 2010-2012 2014-2016
Team Mentor 4509 2013-2014
Team Mentor 3998 2013-2014
Unread 26-01-2017, 22:21
Fusion_Clint's Avatar
Fusion_Clint Fusion_Clint is offline
AKA: Clint Brawley
FRC #0364 (Fusion)
Rookie Year: 2013
Fusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond reputeFusion_Clint has a reputation beyond repute
I think you are looking at it wrong. Each team has a clear view of one of the davits. Teams just need to climb the rope that corresponds to their view.
Clint Brawley
USAF 1992-2013
Fusion 364, 2014 Season to present
Unread 26-01-2017, 22:24
mman1506's Avatar
mman1506 mman1506 is offline
Hater of Tiny Molex Connectors
AKA: Marcus Quintilian
no team (WARP7)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
Don't, if you gear a CIM motor for optimal climb speed you should be able to stall for at least 30 seconds. The pressure plate has a metal U channel that should prevent you from damaging it anyway and while you may worry about it I'm sure FIRST knows plenty of other teams will test its limit. No need to over complicate things.
2014-2015: FRC 865 Warp7 Team Captain
2016: FRC 865 Mentor
2017: Free Agent Mentor, Inspector
Unread 26-01-2017, 22:43
Billfred's Avatar
You were right, I was wrong. Enjoy your rep.
Unread 26-01-2017, 22:54
Chris is me's Avatar
AKA: Pinecone
The light doesn't turn on until after you've pressed it for one second.
Going to just have analog manual control of the speed of the climber, slow down as you get to the top, press it down firmly, not really worried. This shouldn't be hard.
--2016 Waterbury SFs (with 3314, 3719), RIDE #2 Seed / Winners (with 1058, 6153), Carver QFs (with 503, 359, 4607)
-- 2015 TVR Motorola Quality, FLR GM Industrial Design -- 2014 FLR Motorola Quality / SFs (with 341, 4930)
-- 2013 BAE Motorola Quality, WPI Regional #1 Seed / Delphi Excellence in Engineering / Finalists (with 20, 3182)
-- 2012 BAE Imagery / Finalists (with 1519, 885), CT Xerox Creativity / SFs (with 2168, 118)
Student: 1714 (2009) - 2009 MN 10K Lakes Regional Winners (with 2826, 2470)
Unread 26-01-2017, 23:56
Jamesa47 Jamesa47 is offline
FRC #4761 (Robockets)
Team Role: Leadership
Rookie Year: 2014
Jamesa47 is an unknown quantity at this point
A suggestion someone on my team had was to measure the current draw from the climber motor, and when it spikes past a certain point, you know you've hit the top of the rope and are pressing the button down.
Unread 27-01-2017, 01:10
FRC #5202
If you do this, make sure it's a timer to make sure you've pressed for >=1s.
Unread 27-01-2017, 08:48
messer5740's Avatar
messer5740 messer5740 is offline
FRC #5740 (Trojanators)
Team Role: Driver
Rookie Year: 2015
messer5740 is an unknown quantity at this point
You got to make a stop mechanism so you don't slide back down after time is stopped. One the match is done the rope points are calculated, so you got to keep up until the points are GIVEN to the team.
A good driver is always better than a good robot.
2015: Winner of the Rookie Inspiration Award
2016: 8th seed alliance captain at Greater Pittsburgh Regional and 6th seed alliance captain at the Buckeye Regional
Thanks to all our alliance members!
Unread 27-01-2017, 09:00
cad321 cad321 is offline
Jack of all trades, Master of none
AKA: Brian Wagg
FRC #2386 (Trojans)
Rookie Year: 2012
cad321 is just really nicecad321 is just really nicecad321 is just really nicecad321 is just really nice
According to Figure 3-21 in the manual, teams only need to be touching the touchpad for a split second once the match finishes (assuming you were pressing it for longer than one second) in order to receive the points.
  #15   Spotlight this post!
Unread 27-01-2017, 09:28
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Step 1: If your climber is a winch, get rid of all of your sensors and use the PDB's built-in current sensors. When Current / Applied Voltage > a ratio (we're using 60A & 12V, so ratio of 5) then disable the motor from going in that direction for N milliseconds.
Step 2: Test
Step 3: Test Some More.
Current through the motor is responsive and reliable to read and react upon. Getting it from the PDB is one of the best things added to the control system in recent years.
GitHub
