Go to Post Yes, you are correct. Even when all other databuses are totally out of bandwith, the PainInTheCalf Bus gets top priority. Good thinking ;-) - Joe Johnson [more]
Unread 26-01-2017, 22:28
grady404 grady404 is offline
FRC #4019
grady404 is an unknown quantity at this point
Question How to initialize ColorImage object
So for whatever reason I can't figure out for the life of me how to initialize a ColorImage object. I have the following code inside of my robot class:
Code:
static USBCamera camera = new USBCamera("cam0");
static HSLImage snapshot = // what do I put here?
public void teleopInit() {
    camera.openCamera();
    camera.setExposureAuto();
    camera.startCapture();
    camera.getImage(snapshot.image);
    CameraServer.getInstance().setImage(snapshot.image);
Problem is I just can't figure out what line of code I'm supposed to put to initialize the HSLImage object (or RGBImage, or any other type of ColorImage). I've tried the constructor, new HSLImage(), which takes a String for the file path. First of all, there shouldn't be a file path since it's receiving data from the camera directly, and second of all when I do pass in a string I receive an NIVisionException. What do I do? Any help would be greatly appreciated.
Unread 27-01-2017, 17:45
jmcculloch jmcculloch is offline
Jeremy McCulloch
FRC #2485 (W.A.R. (We Are Robot) Lords)
Rookie Year: 2015
jmcculloch is a jewel in the roughjmcculloch is a jewel in the roughjmcculloch is a jewel in the roughjmcculloch is a jewel in the rough
Re: How to initialize ColorImage object
It looks like you are using the old (2016) version of the usb camera and camera server, which is in the NI vision library. You should instead use the new CameraServer and UsbCamera (not USBCamera) class, which are in the cscore and wpilibj libraries. This link should help you get started, and for more complex vision processing, see this link.
