Go to Post In the end any amount of time can work, just be smart about how you use it. - Jay O'Donnell [more]
Go Back   Chief Delphi > Technical > Control System > Sensors
Unread 27-01-2017, 08:29
Stappy Stappy is offline
FRC #5084
Stappy is an unknown quantity at this point
HC-SR04 Ultrasonic Distance Sensor wiring and programming
Ok, so here it goes. Stupid question time.
I am trying to find information about utilizing the HC-SR04 ultrasonic distance sensor in a FIRST Robotics FRC situation with the RoboRIO.
Last year our seasoned programmer could not figure out how to use it and wound up giving up. He has since graduated and moved on to college and a computer science future. That was using C++. He told me that the four wire configuration was not compatible with RoboRIO and would have to use an arduino to translate.
This year I have a transfer team member that is up on programming in Java and I once again asked about the HC-SR04 and was told "Oh that is an arduino only sensor". And yet I see articles regarding the "Venerable HC-SR04" sensor but found nothing on how to wire it or program for it.
The sensor seems pretty standard,
VCC: +5VDC
Trig : Trigger (INPUT)
Echo: Echo (OUTPUT)
GND: GND
What is it about this sensor that keeps it from being used with a RoboRIO?
FridgeBot Inc
Providing robotic appliances since 2014!
Unread 27-01-2017, 10:31
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Rookie Year: 2012
rich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond reputerich2202 has a reputation beyond repute
Re: HC-SR04 Ultrasonic Distance Sensor wiring and programming
Seems like you would:
VCC: +5VDC
Trig : Trigger (INPUT) - DIO<mm>
Echo: Echo (OUTPUT) - DIO<nn>
GND: GND
To use the sensor you would:
1) Reset a Timer to 0
2) Set DIO<mm> to high
3) wait 10us
4) Set DIO<mm> to low
5) See if DIO<nn> is High
6) If high, read Timer, otherwise back to 5 (abort after 1 second)
7) Distance is per the formula
Alternative to 5-7 (which also serves as a double check), see how long DIO<nn> is held high.
Unread 27-01-2017, 10:56
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
LabVIEW has an example of how to use this sensor. It comes in the FRC Update package if you install LabVIEW.
You could use that as a guide and port the example to Java.
Name:	SRF04 Example.jpg
Unread 27-01-2017, 13:51
FRC #5084
So the SRF04 and the HC-SR04 are the same sensor?
FridgeBot Inc
Unread 27-01-2017, 14:16
FRC #5084
NI RoboRio Manual states:
DIO, PWM, and Relay Lines
The NI roboRIO provides the following DIO lines:
• 3.3 V general-purpose DIO lines on the MXP
• 3.3 V digital lines on the DIO, I2C, and SPI ports
• 5 V digital lines on the PWM and Relay ports.
HC-SR04 Specs State:
VCC = +5VDC
Trig = Trigger input of Sensor
Echo = Echo output of Sensor
GND = GND
Is the variation between 3.3v (roboRIO output) and 5v (sensor requirement) where the problem may lay?
Parameter Min Typ. Max Unit Operating Voltage
4.50 5.0 5.5 V
FridgeBot Inc
Unread 27-01-2017, 16:10
Rookie Year: 2012
If you need 5v, the AIO ports are 5 volts. Use 1v and 4v as the threshold, with 1-4 undefined.
