Go to Post You can never take enough precautions when it comes to safety. Please, be prepared for anything. - Tom Bottiglieri [more]
Unread 27-01-2017, 16:40
truell20 truell20 is offline
FRC #5806
truell20 is on a distinguished road
Using ntcore library c++
I am trying to use the ntcore library (github mirror link: https://github.com/wpilibsuite/ntcore) in order to communicate with the roborio from the jetson.
However, I'm not exactly sure how to compile and link the library. Could someone walk me through it?
Unread 27-01-2017, 16:46
jreneew2's Avatar
jreneew2 jreneew2 is offline
Alumni of Team 2053 Tigertronics
AKA: Drew Williams
FRC #2053 (TigerTronics)
Rookie Year: 2013
jreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura aboutjreneew2 has a spectacular aura about
Re: Using ntcore library c++
I was able to successfully compile it on a raspberry pi using the default command they give you in the readme. The Jetson is an ARM processor right?
Try running:
Code:
./gradlew :arm:build
To link the file you should be able to add to your build command
Code:
-I /path/to/lib/folder -l -ntcore
And of course at "ntcore.h" to your file
Unread 27-01-2017, 16:53
FRC #5806
I've done everything that you've suggested, jreneew2, except for the "-I /path/to/lib/folder." I am unsure what "path/to/lib/folder" refers to.
Unread 27-01-2017, 16:55
FRC #5806
"/usr/bin/ld: cannot find -lntcore collect2: error: ld returned 1 exit status"
Is the linker error that I'm currently getting.
Unread 27-01-2017, 17:37
jreneew2's Avatar
AKA: Drew Williams
Rookie Year: 2013
So your include path is where ntcore was compiled. So probably something like /home/ntcore/bin/ntcore/lib.a
Unread 27-01-2017, 21:33
FRC #5806
Got it working. Thanks for the help.
Unread 27-01-2017, 21:34
jreneew2's Avatar
AKA: Drew Williams
Rookie Year: 2013
No problem.
