Go to Post FIRST is here to reach the affluent, already college-bound students with boundless resources; it is also here to reach the poverty-stricken urban and rural students who don't see a diploma as worthwhile, and everybody in between. - Taylor [more]
Unread 27-01-2017, 19:19
thecoopster20 thecoopster20 is offline
4th Year Programmer - Java
FRC #3602 (Robomos)
Rookie Year: 2014
thecoopster20 is an unknown quantity at this point
Multiple Sensor PID Loops
I'm relatively new to programming robots in Java and am looking for some pointers on how to accomplish the following.
Our team wants to be able to do a few PID controlled tasks, mostly with the drive system. We are using a command based structure for our code. Essentially we want to be able to use a few different sensors for a few different tasks, they are as follows:
-Average encoders to drive straight and drive for a certain distance
-Use two ultrasonic sensors to turn the robot until its relatively parallel to a surface as well as drive until we are a certain distance away from a surface
-Utilize vision to turn towards a target
Now, the solutions I've seen so far here on CD are varied. One idea I saw was to create multiple PID loops within the drive subsystem. Another idea was to create separate dummy subsystems specifically for each PID task. I'm not quite sure what the best way to approach this problem is.
