Best Cameras for Computer Vision
I was wondering what are the more-popular/best-regarded cameras in the FRC community for computer vision.
My team is currently using two Microsoft Lifecams. The Lifecam maxes out at 30fps, but I don't see us needing more than that. It seems to have autofocus which is nice. |
Re: Best Cameras for Computer Vision
Pretty much any logitech camera is great for openCV, the most common one being the C270. You can get wider-angle cameras but they are nearly $100, so it's usually easier to just glue a phone camera lens on for a wider FOV.
The Pixy is really popular, and it has a bunch of code and libraries available online.
Our team is rather fond of the Playstation Eye camera that use to be an accessory for the PS3. It costs less than ten dollars and does 60fps at 480p (also 120fps at 320p, but we've never tried that). This is pretty ideal for vision tracking. The image sensor has ridiculously large photosites, so there is very little image noise to worry about. The only downside is that they don't work on Windows systems very well without a third party driver. On the raspberry pi, it works just fine with OpenCV. You can get them on ebay because they are not made any more.
Last season we had great success with the Logitech C920 / 922 / 922x. These cameras are great because they have built in H.264 Encoding, which really took a lot of stress off our vision processing hardware. In order to use the built in encoding, I had to dig up some ancient software (released 1999) in order to run it, but I'm sure there's a better solution.
The Kinect's IR sensor has never let us down. If you have a Jetson board available, you can use the Kinect v2 to get both IR and RGB at the same time (Kinect v2 requires USB 3.0, while Kinect v1 doesn't). Alternatively, you can use the Depth stream as a cheap-mans IR sensor.
We have been able to use the Genius 120-degree (WideCam F100) for multiple years now, which has allowed us to see a greater portion of the field. We were also able to convert the camera to an IR camera by removing the glass filter inside the lens and inserting a clipping of floppy disk between the CMOS and the lens assembly. In 2014, with three of these, we were able to track the entire field, which I wrote about here. I recommend it.
Shameless plug: If you have access to a 3d printer, I've made a minimalist mount for the LifeCam-3000 here: http://www.thingiverse.com/thing:1494829
The Microsoft LifeCam HD‑3000 is one of the most common due to its small size and low price, as well as being available from FIRSTChoice for several years. Axis network cameras are also popular due to their many features and adjustable options. |
#10
The pi works with the camera just fine though. Had two students "struggle" with getting it to work on their Windows and Mac machines but popped it into the pi and it was just fine. Not sure why the roboRio is crippled with only supporting the "uvcvideo" kernel module and none of the other USB webcams. I could understand it if they really nailed that one down but the Wpilib documentation and interaction with v4l2 is so bad even with that limited driver support that it's almost like they didn't try and forced people to get creative. |
#11
Last year we used Logitech c930e for its wide field of view
#13
Some of us remember partying like it's 1999 by the way.... |
#15
