Go to Post A lot of people forget this when posting, but your posts here on ChiefDelphi will more or less be here forever. Do you really want that post you just be made to be on the Internet forever?... Post wisely... - artdutra04 [more]
Unread 30-01-2017, 13:57
RoboChair's Avatar
RoboChair RoboChair is offline
He who fixes with hammers #tsimfd
AKA: Devin Castellucci
FRC #1678 (Citrus Circuits and 5458 Digital Minds)
RoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond reputeRoboChair has a reputation beyond repute
Re: Tubing for ball intake
Originally Posted by Skyehawk View Post
A tutorial would be awesome! Have you tried soapy water/ Murphy's Soap? I know this may not be an ideal solution due to residual soap left after application, but it may just work...
Also I just ordered the components to try this out for myself... should be interesting.
I feel soap would actually be counter productive, it would make it easier to slide off quickly if you mess up the order. But seeing as the latex is literally floating on air there isn't much that the soap would do.
I will post a reminder in our team slack to put the video together during our next meeting on Wed.
12 Years and counting! Over a third of my life has been spent with FRC.
Unread 30-01-2017, 13:51
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
That was a short break
FRC #2826 (Wave Robotics)
EricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond reputeEricLeifermann has a reputation beyond repute
Originally Posted by RoboChair View Post
McMaster Carr specifically we use https://www.mcmaster.com/#5234k91/=1650h8o for our 1.25" OD rollers this year. Yes that is a 0.25" interference.
You cannot pull it on at all. You will need to use compressed air and someone with a reasonably strong arm. Zip-tie/safety-wire one end of the tubing to an air nozzle so that you get a good seal. Next you must plug off your aluminum roller so that air can't flow through it. one person controls air flow, the other holds the tube and tubing and does the hard part. turn on the air and begin pushing the latex on to the aluminum, DO NOT FOR ANY REASON clamp your hand down on the aluminum tube underneath the latex(your hand should never be that far up anyway) or you will get a 100psi balloon animal with a desire to pop. Alternate the airflow on and off to let you move your grip lower on the latex.
If you do not fully understand I can make a youtube video tutorial on Wednesday.
We've found that if you put the air on the end you are trying to pull on to the roller you don't need to plug anything.
Can't tell you which way is faster, it may very well be that yours is...
2002-2005 Appleton East High School: Team 93
2005-2011 Michigan Technological University: Team 857
2012-Present Wave Robotics Team 2826
Unread 30-01-2017, 16:32
clydefrog88's Avatar
clydefrog88 clydefrog88 is offline
Sam
FRC #4087 (Falcon Robotics)
clydefrog88 is a jewel in the roughclydefrog88 is a jewel in the roughclydefrog88 is a jewel in the roughclydefrog88 is a jewel in the rough
Thanks! The devil is in the details, and I love to hear them.
FRC 364 - Mechanical, Operator, Driver (2005-2008)
FRC Machine Judge (2015,2016)
FRC 4087 - Engineering Mentor (2016-?)
Unread 29-01-2017, 21:14
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
Originally Posted by Greg Hainsworth View Post
make sure your tubing stays within the volume box. We considered this too but expect the judges to extend the tubing to it's maximum length and call that the limit of the robot volume.
Good Luck.
*Robot Inspectors, possibly Referees too.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016) | FTC Referee (2017)
Academic Student (Forever)
Unread 30-01-2017, 08:49
Samueldobens Samueldobens is offline
FRC #4908
Samueldobens has much to be proud ofSamueldobens has much to be proud ofSamueldobens has much to be proud ofSamueldobens has much to be proud ofSamueldobens has much to be proud ofSamueldobens has much to be proud ofSamueldobens has much to be proud ofSamueldobens has much to be proud ofSamueldobens has much to be proud of
https://www.mcmaster.com/#flat-drive-belts/=164x37o
Team 341 had success with these for rebound rumble.
http://www.team341.com/history/2012-rebound-rumble/
Unread 30-01-2017, 08:52
FRC #4908
This thread should give you all the information you need.
https://www.chiefdelphi.com/forums/s...ght=flat+belts
