Go to Post We honor those who are unsung - those without a trophy or a plaque to show their efforts. Those who may or may not get those things... but will still be on the sidelines, helping to guide FIRST in all the right directions. - Amanda Morrison [more]
Unread 29-01-2017, 11:10
MuskieProgramme MuskieProgramme is offline
FRC #6420
Rookie Year: 2014
MuskieProgramme is an unknown quantity at this point
Encoders aren't working?
We are using the EVO Shifter with [url="http://www.andymark.com/E4T-OEM-Miniature-Optical-Encoder-Kit-p/am-3132.htm"]E4T OEM Optical Encoders[/ur]. We've wired them to DIO 0-3 on the RIO. The power, ground, and A channel are wired to port 0 / 2 and the B channel is wired to port 1 / 3.
In our code, we are using them like this:
Code:
//RobotMap.java init()
rightDriveEncoder = new Encoder( 0, 1 );
Code:
//DriveWithJoystick.java execute()
SmartDashboard.putString("DB/String 0", "" + RobotMap.rightDriveEncoder.getRate() );
However, the dashboard *always* shows 0.0, no matter what we do. We have verified that the encoder is turning. If we change this to display DigitalInput for port 0, it always displays true.
Have we wired it incorrectly or is there something we should be doing in the code?
Unread 29-01-2017, 11:17
FRC #6420
Rookie Year: 2014
Re: Encoders aren't working?
Sorry, link didn't work out. It should be linked here.
Unread 29-01-2017, 11:39
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
Can you please post or PM me your entire robot program?
Unread 29-01-2017, 12:04
FRC #6420
Rookie Year: 2014
https://github.com/FRC-6420/SteamWorks
Unread 30-01-2017, 09:11
beijing_strbow beijing_strbow is offline
FRC #5968 (Cyborg Indians)
Rookie Year: 2016
beijing_strbow is an unknown quantity at this point
The encoder initialization in RobotMap is commented out right now (probably intentional, but just in case). Other than that, I would guess it's a wiring issue, because your code seems correct.
Side note: you probably want to check the bandwidth your camera stream uses. A 640x480 stream at 30 fps (I think that's what you have it at) is quite likely to consume too much bandwidth.
Unread 31-01-2017, 14:13
FRC #6420
Rookie Year: 2014
Got to revisit the problem last night, started debugging things with a multimeter... turns out the person who wired the encoders had broken the encoder wire in several places by zip tying it in a bundle. I now have a good story to bring up whenever something's blamed on the programming
