Setting FPS and resolution of USB camera server
Basically, the title. I want to use the roboRIO to forward the image from a Microsoft Lifecam to a Raspberry Pi, at about 12 - 15 FPS @ 240p, as well as have the stream be visible on the driver station.
Re: Setting FPS and resolution of USB camera server
This is how you do it in Java.
We use separate cameras for streaming and vision processing, because it works much better for processing if you turn the brightness and exposure way down so you can only see the really bright stuff. LifeCams are pretty cheap, so it may be worth looking into. |
https://www.chiefdelphi.com/forums/s...d.php?t=154388 |
