Go to Post The only people who are dumb or ignorant in this world are the ones who don't stop and ask why. - T967 [more]
Unread 30-01-2017, 17:32
mfkahn mfkahn is offline
FRC #3543
mfkahn is an unknown quantity at this point
GRIP Java code generation and blob detection
Hi all:
We had an issue where image processing, specifically blob detection, using generated java code from GRIP did not match what was shown in the GRIP GUI. Digging into OpenCV and GRIP we found https://github.com/WPIRoboticsProjects/GRIP/issues/811
If you are using a version of GRIP from before the fix, you will need to fix the generated source as per the notes in the issue.
Unread 30-01-2017, 18:16
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Re: GRIP Java code generation and blob detection
To clarify, this was fixed with version 1.5.2.
WPILib
GRIP, RobotBuilder
Unread 30-01-2017, 21:02
FRC #3543
Thanks btw for the really fast fix!
