Go to Post Maybe we should have some safety training before and during build instead of just having flyers at our pit. Hm... - JaneYoung [more]
Unread 30-01-2017, 18:35
ap303's Avatar
ap303 ap303 is offline
FRC #0303
ap303 is an unknown quantity at this point
Robo Rio User Logs
At random intervals while running open CV code, the rio will crash and refuse to connect over ethernet or usb. Because of this, we can't get the crash report until we reset the rio. When we reset it, the new log overwrites the old one. Does anyone know if there's a way to get the logs to save?
Thanks
My opinions do not necessarily reflect those of my team.
Unread 31-01-2017, 08:00
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Robo Rio User Logs
Thanks
Anything in the DriverStation log viewer?
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 31-01-2017, 08:55
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
You might try disabling automatic user code start through the roboRIO web browser page.
Then start your user code via command line.
Unread 31-01-2017, 17:33
ap303's Avatar
FRC #0303
We managed to SSH into the Rio but we are having trouble running the code through the Linux terminal using the command
Code:
java -jar FRCUserProgram.jar
. It gives the error message
Code:
-sh: java: command not found
. What is the command to run the user code?
Thanks
Unread 31-01-2017, 18:04
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Assuming you SSH'd as lvuser, run
Code:
./FRCRunRobotProgram.sh
(I forget the actual name of the script... it's close to what I wrote above)
WPILib
GRIP, RobotBuilder
