This is our build console. Whenever we try to submit our code, it makes communication and the build is succesful, but the driver station still has a red light for the driver station. When I use an example program, it works. What could the problem be?
Buildfile: C:\Users\Matan\workspace\MEME-Powered\build.xml Trying to override old definition of task classloader clean: [delete] Deleting directory C:\Users\Matan\workspace\MEME-Powered\build [delete] Deleting directory C:\Users\Matan\workspace\MEME-Powered\dist compile: [mkdir] Created dir: C:\Users\Matan\workspace\MEME-Powered\build [echo] [athena-compile] Compiling src with classpath=C:\Users\Matan\wpilib\java\current\lib\W PILib.jar;C:\Users\Matan\wpilib\java\current\lib\N etworkTables.jar;C:\Users\Matan\wpilib\java\curren t\lib\opencv.jar;C:\Users\Matan\wpilib\java\curren t\lib\cscore.jar to build [javac] Compiling 11 source files to C:\Users\Matan\workspace\MEME-Powered\build jar: [echo] [athena-jar] Making jar dist/FRCUserProgram.jar. [mkdir] Created dir: C:\Users\Matan\workspace\MEME-Powered\dist [mkdir] Created dir: C:\Users\Matan\workspace\MEME-Powered\build\jars [echo] [athena-jar] Copying jars to build/jars. [copy] Copying 4 files to C:\Users\Matan\workspace\MEME-Powered\build\jars [jar] Building jar: C:\Users\Matan\workspace\MEME-Powered\dist\FRCUserProgram.jar get-target-ip: [echo] Finding roboRIO, please ignore any [hostinfo] error messages [echo] Trying DNS: roboRIO-4572-FRC.lan [echo] Trying USB: 172.22.11.2 [echo] Trying mDNS: roboRIO-4572-FRC.local [echo] Trying Static Ethernet: 10.45.72.2 [hostinfo] Error retrieving remote host information for host:roboRIO-4572-FRC.lan. [echo] Resolved mDNS to 10.45.72.31 [echo] roboRIO found at 10.45.72.31 dependencies: [echo] roboRIO image version validated [echo] Checking for JRE. If this fails install the JRE using these instructions: https://wpilib.screenstepslive.com/s...ller-java-only [sshexec] Connecting to 10.45.72.31:22 [sshexec] cmd : test -d /usr/local/frc/JRE deploy: [delete] Deleting: C:\Users\Matan\wpilib\java\current\lib\native\lib\ WPI_Native_Libraries.properties [scp] Connecting to 10.45.72.31:22 [scp] Receiving file: /usr/local/frc/lib/WPI_Native_Libraries.properties [scp] Receiving: WPI_Native_Libraries.properties : 2598 [scp] File transfer time: 0.01 Average Rate: 519,600.0 B/s [scp] done [scp] Connecting to 10.45.72.31:22 [scp] Receiving file: /usr/local/frc/lib/User_Libraries.properties [scp] Caught exception: scp: /usr/local/frc/lib/User_Libraries.properties: No such file or directory [echo] [athena-deploy] Copying code over. [scp] Connecting to 10.45.72.31:22 [scp] done. [sshexec] Connecting to 10.45.72.31:22 [sshexec] cmd : ldconfig [sshexec] Connecting to 10.45.72.31:22 [sshexec] cmd : killall -q netconsole-host || : [delete] Deleting: C:\Users\Matan\wpilib\java\current\ant\netconsole-host.properties [scp] Connecting to 10.45.72.31:22 [scp] Receiving file: /usr/local/frc/bin/netconsole-host.properties [scp] Receiving: netconsole-host.properties : 134 [scp] File transfer time: 0.0 Average Rate: 33,500.0 B/s [scp] done [scp] Connecting to 10.45.72.31:22 [scp] done. [echo] [athena-deploy] Starting program. [sshexec] Connecting to 10.45.72.31:22 [sshexec] cmd : . /etc/profile.d/natinst-path.sh; /usr/local/frc/bin/frcKillRobot.sh -t -r; [sshexec] Connecting to 10.45.72.31:22 [sshexec] cmd : sync BUILD SUCCESSFUL Total time: 10 seconds |
