Go to Post There can never be enough help, unless there's too much help. - Joshua May [more]
Unread 31-01-2017, 16:34
riptide321 riptide321 is offline
FRC #4404
riptide321 is an unknown quantity at this point
Exclamation RoboRio Imaging Error: Novice Coder
This is an error that I am getting while trying to image the RoboRio:
Unable to download image to target. Unable to complete operation
because of unexpected errornisyscfg.lvliblnitialize (Helper).vi:
3930001<APPEND>
<b>Complete call chain:</b>
nisyscfg.lvlib:Initialize (Helper).vi:3930001
nisyscfg.lvlib:Initialize Session.vi:1230001
RoboRIOImagingTool.lvlib:Open Session.vi
RoboRIOImagingToolivlib:Reconfig Device.vi
RoboRIOImagingToolivliblmageManager.vi
RoboRIOImagingToolivliblmagingToolMain.vi
What is the solution?
Unread 31-01-2017, 18:25
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
Re: RoboRio Imaging Error: Novice Coder
Double check that:
  1. Your firewall is disabled
  2. Nothing is plugged into your computer except the roboRIO
  3. Nothing is plugged into the roboRIO except the USB cable connected to your computer and power.
If reimagining after checking those things still does not work, try booting into safe mode:
http://wpilib.screenstepslive.com/s/...sing-safe-mode
