Go to Post You win Worlds by innovation. You win Worlds by determination. You win Worlds by engineering a robot so solid, that it successfully completes the game. - Zach O [more]
Unread 31-01-2017, 19:26
randy_pham randy_pham is offline
FRC #0498 (Cobra Commanders)
Rookie Year: 2016
randy_pham is an unknown quantity at this point
Analog Input not working for Ultrasonic Sensor
We keep trying to get the ultrasonic sensor to work, but it keeps telling us that there is an error initializing the ports. We have tried to change the ports several times, and it still is not working.
Here is our Robot.java class:
Code:
//Made in Japan
package org.usfirst.frc.team498.robot;
import java.util.HashMap;
import java.util.Map;
import edu.wpi.first.wpilibj.AnalogInput;
import edu.wpi.first.wpilibj.DigitalInput;
import edu.wpi.first.wpilibj.DoubleSolenoid;
import edu.wpi.first.wpilibj.I2C;
import edu.wpi.first.wpilibj.DoubleSolenoid.Value;
import edu.wpi.first.wpilibj.I2C.Port;
import edu.wpi.first.wpilibj.PowerDistributionPanel;
import edu.wpi.first.wpilibj.SampleRobot;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Ultrasonic;
import edu.wpi.first.wpilibj.command.Command;
//import edu.wpi.first.wpilibj.networktables.NetworkTable; *garbage*
public class Robot extends SampleRobot {
	Command autonomousCommand;
	 * //Network tables NetworkTable table; *garbage*
	// Drive
	Ports ports = new Ports();
	private Timer clock;
	FancyJoystick thisStick = new FancyJoystick(0);
	Drive2017 drive = new Drive2017(thisStick, ports);
	REVImprovedDigitBoard digitBoard = new REVImprovedDigitBoard();
	PewPew2017 shooter = new PewPew2017(digitBoard, thisStick, ports);
	AutonmousController auto = new AutonmousController(drive, shooter, digitBoard, ports);
	//GearIntake2017 gearIntake = new GearIntake2017(thisStick, ports);
	AnalogUltrasonicSensor2017 ultra = new AnalogUltrasonicSensor2017(ports);
	PowerDistributionPanel pdp = new PowerDistributionPanel();
	@Override
	public void robotInit() {
		// table = NetworkTable.getTable("datatable"); *garbage*
		// CameraServer.getInstance().startAutomaticCapture();
		 * new Thread(() -> { UsbCamera camera =
		 * CameraServer.getInstance().startAutomaticCapture();
		 * camera.setResolution(640, 480);
		 * CvSink cvSink = CameraServer.getInstance().getVideo(); CvSource
		 * outputStream = CameraServer.getInstance().putVideo("Blur", 640, 480);
		 * Mat source = new Mat(); Mat output = new Mat();
		 * while(true) { cvSink.grabFrame(source); Imgproc.cvtColor(source,
		 * output, Imgproc.COLOR_BGR2GRAY); outputStream.putFrame(output); }
		 * }).start(); }
		// 2 USB Cameras
		 * frame = NIVision.imaqCreateImage(NIVision.ImageType.IMAGE_RGB, 0);
		 * sessionfront = NIVision.IMAQdxOpenCamera("cam1",
		 * NIVision.IMAQdxCameraControlMode.CameraControlModeController);
		 * sessionback = NIVision.IMAQdxOpenCamera("cam2",
		 * currSession = sessionfront;
		 * NIVision.IMAQdxConfigureGrab(currSession);
	// Select which autonomous to run
	public void autonomous() {
		// auto.autoInit(-1); // This autonomous method is copied from Unnamed
		// Mark
		// 4
	int count = 0;
	int count2 = 0;
	public void operatorControl() {
		// For Network table double x = 0; *garbage* double y = 0;
		drive.moveValue = 0;
		drive.turnValue = 0;
		// auto.gyro.reset();
		TeleOpMode teleMode = TeleOpMode.OPERATORCONTROL;
		// digitBoard.display(2.0);
		digitBoard.CreateScrollMsg("Randy Left Early    ");
		while (isOperatorControl() && isEnabled()) {
			if (count % 1000 == 0) {
				digitBoard.SlideScrollMsg();
			count++;
			if(thisStick.getButton(Button.Y)) { // 0.735 on smart dashboard is perfect!
			shooter.Shoot();
			} else {
				shooter.StopShoot();
			// network table
			 * Timer.delay(0.25); table.putNumber("X", x); *garbage*
			 * table.putNumber("Y", y); x += 0.05; y +=1.0;
			// 2 camera code
			 * if(button pressing code){ if(currSession == sessionfront){
			 * NIVision.IMAQdxStopAcquisition(currSession); currSession =
			 * sessionback; NIVision.IMAQdxConfigureGrab(currSession); } else
			 * if(currSession == sessionback){
			 * sessionfront; NIVision.IMAQdxConfigureGrab(currSession); } }
			// Checks button
			if (thisStick.getButton(Button.BACK) && thisStick.getButton(Button.B)) {
				// TODO climbing feature
			if (thisStick.getButton(Button.B)) {
				teleMode = TeleOpMode.GEARALIGNMENT; // aligns robot to peg
			if (thisStick.getButton(Button.START)) {
				teleMode = TeleOpMode.OPERATORCONTROL; // makes robot go back to
														// TeleOp
			if (thisStick.getButton(Button.X)) {
				teleMode = TeleOpMode.TEST; // Testing code
			switch (teleMode) {
			case OPERATORCONTROL:
				// Drive the robot via controller
				drive.rampedDriveListener();
				//gearIntake.Listener();
				// shooter.shootListener();
				break;
			case GEARALIGNMENT:
				// teleMode = auto.AlignGearPeg();
				break;
			case HIGHGOALALIGNMENT:
				// teleMode = auto.AlignHighGoal();
				break;
			case TEST:
				// auto.testDrive();
				break;
			// Send stats to the driver
			print();
	public void disabled() {
		while (isDisabled()) {
			print();
			if (digitBoard.getButtonA()) {
				auto.autonomousSelector(); // Displays auto on digit board
	// Sends information to the driver
	private void print() {
		// SmartDashboard.putNumber("Gyro Angle", auto.gyro.getAngle());
		// SmartDashboard.putNumber("Gyro getRate()", auto.gyro.getRate());
		// SmartDashboard.putNumber("Range (Inches)", ultra.GetRangeInches());
		// SmartDashboard.putNumber("Ultrasonic Voltage", ultra.GetVoltage());
		SmartDashboard.putNumber("Shooter value", digitBoard.getPot());
		 * SmartDashboard.putNumber("Range millimeters (Analog)",
		 * auto.analogSensor.GetRangeMM());
		 * SmartDashboard.putNumber("Range Inches (Analog)",
		 * auto.analogSensor.GetRangeInches());
		 * SmartDashboard.putNumber("Voltage (Analog)",
		 * auto.analogSensor.GetVoltage());
		 * // These should print out GRIP's contour info into Dashboard
		 * SmartDashboard.putNumber("Contour1 CenterX",
		 * auto.vision.GetContour1CenterX());
		 * SmartDashboard.putNumber("Contour1 CenterY",
		 * auto.vision.GetContour1CenterY());
		 * SmartDashboard.putNumber("Contour1 Height",
		 * auto.vision.GetContour1Height());
		 * SmartDashboard.putNumber("Contour2 CenterX",
		 * auto.vision.GetContour2CenterX());
		 * SmartDashboard.putNumber("Contour2 CenterY",
		 * auto.vision.GetContour2CenterY());
		 * SmartDashboard.putNumber("Contour2 Height",
		 * auto.vision.GetContour2Height());
		 * SmartDashboard.putBoolean("flag", auto.vision.flag);
		 * // SmartDashboard.putNumber("Battery Voltage", pdp.getVoltage());
		 * //SmartDashboard.putNumber("Potentiometer Value",
		 * digitBoard.getPot()); SmartDashboard.putNumber("Move Value",
		 * drive.moveValue);
		 * //SmartDashboard.putBoolean("Button A", digitBoard.getButtonA());
		 * //SmartDashboard.putBoolean("Button B", digitBoard.getButtonB());
		 * SmartDashboard.putNumber("AutoMode", auto.autoMode);
		 * SmartDashboard.putString("Display", auto.display); //
		 * SmartDashboard.putNumber("A7", potMaybe.getVoltage());
		 * // digitBoard.display(pdp.getVoltage());
		 * // SmartDashboard.putNumber("Ramp Clock", //
		 * drive.forwardDriveRamp.clock.get());
		 * // 2 camera code /* 8NIVision.IMAQdxGrab(currSession, frame, 1);
		 * CameraServer.getInstance().setImage(frame);
Here is our ports class:
Code:
public class Ports {
	// Motor controllers
	final int LEFT_FRONT_PWM_PORT = 2; // 8, 2
	final int LEFT_BACK_PWM_PORT = 1; // 9, 1
	final int RIGHT_FRONT_PWM_PORT = 4;// 6, 4
	final int RIGHT_BACK_PWM_PORT = 3;// 7, 3
	final int SHOOTER_PWM_PORT = 5;
	final int GEAR_INTAKE_FORWARD_CHANNEL = 0;
	final int GEAR_INTAKE_REVERSE_CHANNEL = 1;
	// 1 is 9, 2 is 8, 3 is 7, 4 is 6
	// We have two talons with CAN wires
	// analog sensors
	final int ULTRASONIC_SENSOR_ANALOG_PORT = 0; // TODO: change port to
													// something other than 0 or
													// 1 on robot
	// final int ULTRASONIC_SENSOR_PCM_PORT = 0;
	// ramp code
	final double forwardRampIncreaseValue = 1.3;
	final double reverseRampIncreaseValue = .1;
	final double turningRampIncreaseValue = 1.3;
	final double speedCap = .85;
Here is our AnalogUltrasonicSensor2017 class:
Code:
public class AnalogUltrasonicSensor2017 {
	AnalogInput AI;
	public AnalogUltrasonicSensor2017(Ports ports) {
		AI = new AnalogInput(ports.ULTRASONIC_SENSOR_ANALOG_PORT); // !!!MUY
																	// IMPORTANTE!!!
	public double GetRangeMM() {
		double output = 0;
		output = AI.getVoltage();
		output = output / 1000; // Measured in millivolts
		output = output / 0.977;
		return output;
	public double GetRangeInches() {
		double output = GetRangeMM();
		output = output * 25.4;
		return output;
	public double GetVoltage() {
		return AI.getVoltage();
Here is the AnalogInput class (from the referenced libraries)
Code:
/* Copyright (c) FIRST 2008-2017. All Rights Reserved.                        */
/* Open Source Software - may be modified and shared by FRC teams. The code   */
/* must be accompanied by the FIRST BSD license file in the root directory of */
/* the project.                                                               */
package edu.wpi.first.wpilibj;
import java.nio.ByteBuffer;
import java.nio.ByteOrder;
import edu.wpi.first.wpilibj.hal.AnalogJNI;
import edu.wpi.first.wpilibj.hal.FRCNetComm.tResourceType;
import edu.wpi.first.wpilibj.hal.HAL;
import edu.wpi.first.wpilibj.livewindow.LiveWindow;
import edu.wpi.first.wpilibj.livewindow.LiveWindowSendable;
import edu.wpi.first.wpilibj.tables.ITable;
import edu.wpi.first.wpilibj.util.AllocationException;
 * Analog channel class.
 * <p>Each analog channel is read from hardware as a 12-bit number representing 0V to 5V.
 * <p>Connected to each analog channel is an averaging and oversampling engine. This engine
 * accumulates the specified ( by setAverageBits() and setOversampleBits() ) number of samples
 * before returning a new value. This is not a sliding window average. The only difference between
 * the oversampled samples and the averaged samples is that the oversampled samples are simply
 * accumulated effectively increasing the resolution, while the averaged samples are divided by the
 * number of samples to retain the resolution, but get more stable values.
public class AnalogInput extends SensorBase implements PIDSource, LiveWindowSendable {
  private static final int kAccumulatorSlot = 1;
  int m_port; // explicit no modifier, private and package accessable.
  private int m_channel;
  private static final int[] kAccumulatorChannels = {0, 1};
  private long m_accumulatorOffset;
  protected PIDSourceType m_pidSource = PIDSourceType.kDisplacement;
   * Construct an analog channel.
   * @param channel The channel number to represent. 0-3 are on-board 4-7 are on the MXP port.
  public AnalogInput(final int channel) {
    m_channel = channel;
    SensorBase.checkAnalogInputChannel(channel);
    final int portHandle = AnalogJNI.getPort((byte) channel);
    m_port = AnalogJNI.initializeAnalogInputPort(portHandle);
    LiveWindow.addSensor("AnalogInput", channel, this);
    HAL.report(tResourceType.kResourceType_AnalogChannel, channel);
   * Channel destructor.
  public void free() {
    AnalogJNI.freeAnalogInputPort(m_port);
    m_port = 0;
    m_channel = 0;
    m_accumulatorOffset = 0;
   * Get a sample straight from this channel. The sample is a 12-bit value representing the 0V to 5V
   * range of the A/D converter. The units are in A/D converter codes. Use GetVoltage() to get the
   * analog value in calibrated units.
   * @return A sample straight from this channel.
  public int getValue() {
    return AnalogJNI.getAnalogValue(m_port);
   * Get a sample from the output of the oversample and average engine for this channel. The sample
   * is 12-bit + the bits configured in SetOversampleBits(). The value configured in
   * setAverageBits() will cause this value to be averaged 2^bits number of samples. This is not a
   * sliding window. The sample will not change until 2^(OversampleBits + AverageBits) samples have
   * been acquired from this channel. Use getAverageVoltage() to get the analog value in calibrated
   * units.
   * @return A sample from the oversample and average engine for this channel.
  public int getAverageValue() {
    return AnalogJNI.getAnalogAverageValue(m_port);
   * Get a scaled sample straight from this channel. The value is scaled to units of Volts using the
   * calibrated scaling data from getLSBWeight() and getOffset().
   * @return A scaled sample straight from this channel.
  public double getVoltage() {
    return AnalogJNI.getAnalogVoltage(m_port);
   * Get a scaled sample from the output of the oversample and average engine for this channel. The
   * value is scaled to units of Volts using the calibrated scaling data from getLSBWeight() and
   * getOffset(). Using oversampling will cause this value to be higher resolution, but it will
   * update more slowly. Using averaging will cause this value to be more stable, but it will update
   * more slowly.
   * @return A scaled sample from the output of the oversample and average engine for this channel.
  public double getAverageVoltage() {
    return AnalogJNI.getAnalogAverageVoltage(m_port);
   * Get the factory scaling least significant bit weight constant. The least significant bit weight
   * constant for the channel that was calibrated in manufacturing and stored in an eeprom.
   * <p>Volts = ((LSB_Weight * 1e-9) * raw) - (Offset * 1e-9)
   * @return Least significant bit weight.
  public long getLSBWeight() {
    return AnalogJNI.getAnalogLSBWeight(m_port);
   * Get the factory scaling offset constant. The offset constant for the channel that was
   * calibrated in manufacturing and stored in an eeprom.
   * @return Offset constant.
  public int getOffset() {
    return AnalogJNI.getAnalogOffset(m_port);
   * Get the channel number.
   * @return The channel number.
  public int getChannel() {
    return m_channel;
   * Set the number of averaging bits. This sets the number of averaging bits. The actual number of
   * averaged samples is 2^bits. The averaging is done automatically in the FPGA.
   * @param bits The number of averaging bits.
  public void setAverageBits(final int bits) {
    AnalogJNI.setAnalogAverageBits(m_port, bits);
   * Get the number of averaging bits. This gets the number of averaging bits from the FPGA. The
   * actual number of averaged samples is 2^bits. The averaging is done automatically in the FPGA.
   * @return The number of averaging bits.
  public int getAverageBits() {
    return AnalogJNI.getAnalogAverageBits(m_port);
   * Set the number of oversample bits. This sets the number of oversample bits. The actual number
   * of oversampled values is 2^bits. The oversampling is done automatically in the FPGA.
   * @param bits The number of oversample bits.
  public void setOversampleBits(final int bits) {
    AnalogJNI.setAnalogOversampleBits(m_port, bits);
   * Get the number of oversample bits. This gets the number of oversample bits from the FPGA. The
   * actual number of oversampled values is 2^bits. The oversampling is done automatically in the
   * FPGA.
   * @return The number of oversample bits.
  public int getOversampleBits() {
    return AnalogJNI.getAnalogOversampleBits(m_port);
   * Initialize the accumulator.
  public void initAccumulator() {
    if (!isAccumulatorChannel()) {
      throw new AllocationException("Accumulators are only available on slot " + kAccumulatorSlot
          + " on channels " + kAccumulatorChannels[0] + ", " + kAccumulatorChannels[1]);
    AnalogJNI.initAccumulator(m_port);
   * Set an initial value for the accumulator.
   * <p>This will be added to all values returned to the user.
   * @param initialValue The value that the accumulator should start from when reset.
  public void setAccumulatorInitialValue(long initialValue) {
    m_accumulatorOffset = initialValue;
   * Resets the accumulator to the initial value.
  public void resetAccumulator() {
    AnalogJNI.resetAccumulator(m_port);
    // Wait until the next sample, so the next call to getAccumulator*()
    // won't have old values.
    final double sampleTime = 1.0 / getGlobalSampleRate();
    final double overSamples = 1 << getOversampleBits();
    final double averageSamples = 1 << getAverageBits();
    Timer.delay(sampleTime * overSamples * averageSamples);
   * Set the center value of the accumulator.
   * <p>The center value is subtracted from each A/D value before it is added to the accumulator.
   * This is used for the center value of devices like gyros and accelerometers to take the device
   * offset into account when integrating.
   * <p>This center value is based on the output of the oversampled and averaged source the
   * accumulator channel. Because of this, any non-zero oversample bits will affect the size of the
   * value for this field.
  public void setAccumulatorCenter(int center) {
    AnalogJNI.setAccumulatorCenter(m_port, center);
   * Set the accumulator's deadband.
   * @param deadband The deadband size in ADC codes (12-bit value)
  public void setAccumulatorDeadband(int deadband) {
    AnalogJNI.setAccumulatorDeadband(m_port, deadband);
   * Read the accumulated value.
   * <p>Read the value that has been accumulating. The accumulator is attached after the oversample
   * and average engine.
   * @return The 64-bit value accumulated since the last Reset().
  public long getAccumulatorValue() {
    return AnalogJNI.getAccumulatorValue(m_port) + m_accumulatorOffset;
   * Read the number of accumulated values.
   * <p>Read the count of the accumulated values since the accumulator was last Reset().
   * @return The number of times samples from the channel were accumulated.
  public long getAccumulatorCount() {
    return AnalogJNI.getAccumulatorCount(m_port);
   * Read the accumulated value and the number of accumulated values atomically.
   * <p>This function reads the value and count from the FPGA atomically. This can be used for
   * averaging.
   * @param result AccumulatorResult object to store the results in.
  public void getAccumulatorOutput(AccumulatorResult result) {
    if (result == null) {
      throw new IllegalArgumentException("Null parameter `result'");
          "Channel " + m_channel + " is not an accumulator channel.");
    ByteBuffer value = ByteBuffer.allocateDirect(8);
    // set the byte order
    value.order(ByteOrder.LITTLE_ENDIAN);
    ByteBuffer count = ByteBuffer.allocateDirect(8);
    count.order(ByteOrder.LITTLE_ENDIAN);
    AnalogJNI.getAccumulatorOutput(m_port, value.asLongBuffer(), count.asLongBuffer());
    result.value = value.asLongBuffer().get(0) + m_accumulatorOffset;
    result.count = count.asLongBuffer().get(0);
   * Is the channel attached to an accumulator.
   * @return The analog channel is attached to an accumulator.
  public boolean isAccumulatorChannel() {
    for (int i = 0; i < kAccumulatorChannels.length; i++) {
      if (m_channel == kAccumulatorChannels[i]) {
        return true;
    return false;
   * Set the sample rate per channel.
   * <p>This is a global setting for all channels. The maximum rate is 500kS/s divided by the number
   * of channels in use. This is 62500 samples/s per channel if all 8 channels are used.
   * @param samplesPerSecond The number of samples per second.
  public static void setGlobalSampleRate(final double samplesPerSecond) {
    AnalogJNI.setAnalogSampleRate(samplesPerSecond);
   * Get the current sample rate.
   * <p>This assumes one entry in the scan list. This is a global setting for all channels.
   * @return Sample rate.
  public static double getGlobalSampleRate() {
    return AnalogJNI.getAnalogSampleRate();
  @Override
  public void setPIDSourceType(PIDSourceType pidSource) {
    m_pidSource = pidSource;
  @Override
  public PIDSourceType getPIDSourceType() {
    return m_pidSource;
   * Get the average voltage for use with PIDController.
   * @return the average voltage
  @Override
  public double pidGet() {
    return getAverageVoltage();
   * Live Window code, only does anything if live window is activated.
  @Override
  public String getSmartDashboardType() {
    return "Analog Input";
  private ITable m_table;
  @Override
  public void initTable(ITable subtable) {
    m_table = subtable;
    updateTable();
  @Override
  public void updateTable() {
    if (m_table != null) {
      m_table.putNumber("Value", getAverageVoltage());
  @Override
  public ITable getTable() {
    return m_table;
   * Analog Channels don't have to do anything special when entering the LiveWindow. {@inheritDoc}
  @Override
  public void startLiveWindowMode() {
   * Analog Channels don't have to do anything special when exiting the LiveWindow. {@inheritDoc}
  @Override
  public void stopLiveWindowMode() {
Any help is appreciated, we just don't know what's happening. The code deploys correctly, which suggests that it is a runtime exception. The driver station says No Robot Code, then proceeds to puke errors at us. These are the errors we are experiencing:
Code:
ERROR  1  ERROR Unhandled exception instantiating robot org.usfirst.frc.team498.robot.Robot java.lang.RuntimeException:  Code: -1029. HAL: Resource already allocated at [edu.wpi.first.wpilibj.hal.AnalogJNI.initializeAnalogInputPort(Native Method), edu.wpi.first.wpilibj.AnalogInput.<init>(AnalogInput.java:53), org.usfirst.frc.team498.robot.AnalogUltrasonicSensor2017.<init>(AnalogUltrasonicSensor2017.java:9), org.usfirst.frc.team498.robot.Robot.<init>(Robot.java:39), sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method), sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62), sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45), java.lang.reflect.Constructor.newInstance(Constructor.java:408), java.lang.Class.newInstance(Class.java:433), edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:216)]  edu.wpi.first.wpilibj.RobotBase.main(RobotBase.java:218)
WARNING: Robots don't quit!
ERROR: Could not instantiate robot org.usfirst.frc.team498.robot.Robot!
Thanks for any help
Unread 02-02-2017, 14:15
pblankenbaker pblankenbaker is offline
FRC #0868
pblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of light
Re: Analog Input not working for Ultrasonic Sensor
Based on the stack trace, my best guess is that there is more than one place in your code where an AnalogInput object is created on port 0. However, I do not see anything in the code you posted that would cause this. Is it possible that one of the following is true?
  • You have have other locations in your source code that construct an AnalogInput using the same channel number?
  • You have have other locations in your source code that construct an AnalogUltrasonicSensor2017 command (that would result in an attempt to construct an AnalogInput on the same channel).
For the latter case, you can change your AnalogUltrasonicSensor2017 class so that multiple instances will refer to a single static/shared AnalogInput. This can be done with the following changes:
Code:
	private static AnalogInput AI = null;
                if (AI == null) {
That should allow you to construct multiple instances of this command. If you are willing to declare your constants in Ports as static, it could be simplified to:
Code:
	private static AnalogInput AI = new AnalogInput(ports.ULTRASONIC_SENSOR_ANALOG_PORT);
