Go to Post If that due diligence shows that a real need for action exists, *then* grab the pitchforks, and light the torches. - gblake [more]
Unread 31-01-2017, 22:36
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
Rookie Year: 2011
fovea1959 will become famous soon enough
MXP Expansion Pins
I was looking at the docs for the MXP expansion port, and see that some of the pins are labelled for multiple functions.
For example, pin 31 is labelled "DIO 10/PWM 6". I imagine it can be used as either a PWM or DIO, but what determines which it is?
Where is the reference for how to map Roborio channels to the MXP expansion pins?
Unread 31-01-2017, 23:06
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Re: MXP Expansion Pins
Try this page:
http://www.pdocs.kauailabs.com/navx-.../io-expansion/
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 01-02-2017, 09:49
fovea1959's Avatar
AKA: Doug Wegscheid
Rookie Year: 2011
Missed that one; was working off the MXP pinouts. Thanks!
If I do a "new DigitalInput(10)" in my Java code, Navx/MXP port 0 functions as a DIO, and if I do a "new Talon(10)" in the code, if functions as a PWM, and if I do both, I will have a bad debugging session?
I was wondering about a pin being either a DIO, PWM, or SPI/I2C, but I missed the break in numbering in the DIOs; a pin that can be used as a DIO can be also be used as only *one* of PWM/I2C/SPI, and can only be used as one of those functions (a DIO or the altenative...)
https://github.com/kauailabs/navxmxp...bot/Robot.java also helps.
