Go to Post I hope Dave doesn't see these. He'll want you to put in a banana and use it for a game clue. - IndySam [more]
Unread 01-02-2017, 00:51
rtrahms's Avatar
rtrahms rtrahms is offline
FRC #1778 (Chill Out!)
Rookie Year: 2013
rtrahms is a jewel in the roughrtrahms is a jewel in the roughrtrahms is a jewel in the rough
Intermittent Sendable Chooser output on Smart Dashboard
Hi all -
We use the SendableChooser class for creating our autonomous options:
chooser = new SendableChooser();
chooser.addDefault("DO_NOTHING", DO_NOTHING);
chooser.addObject("DRIVE_FORWARD", DRIVE_FORWARD);
chooser.addObject("DEPOSIT_GEAR_LEFT", DEPOSIT_GEAR_LEFT);
chooser.addObject("DEPOSIT_GEAR_CENTER", DEPOSIT_GEAR_CENTER);
chooser.addObject("DEPOSIT_GEAR_RIGHT", DEPOSIT_GEAR_RIGHT);
chooser.addObject("DRIVE_AND_SHOOT_BLUE_LEFT", DRIVE_AND_SHOOT_BLUE_LEFT);
chooser.addObject("DRIVE_AND_SHOOT_BLUE_CENTER", DRIVE_AND_SHOOT_BLUE_CENTER);
chooser.addObject("DRIVE_AND_SHOOT_BLUE_RIGHT", DRIVE_AND_SHOOT_BLUE_RIGHT);
chooser.addObject("DRIVE_AND_SHOOT_RED_LEFT", DRIVE_AND_SHOOT_RED_LEFT);
chooser.addObject("DRIVE_AND_SHOOT_RED_CENTER", DRIVE_AND_SHOOT_RED_CENTER);
chooser.addObject("DRIVE_AND_SHOOT_RED_RIGHT", DRIVE_AND_SHOOT_RED_RIGHT);
SmartDashboard.putData("Auto_Mode_Chooser", chooser);
When we start up smart dashboard, these options appear, and work... most of the time. Sometimes when we start smart dashboard, the options are not present. Restarting the dashboard once or twice is usually all it takes, but this looks to be a 'missed transaction' between the robot and the driver station. Has anyone had a similar experience? If so, how did you solve it?
Thanks.
Software Mentor
FRC Team 1778 - Chill Out!
Mountlake Terrace High School
Unread 01-02-2017, 01:10
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Re: Intermittent Sendable Chooser output on Smart Dashboard
NetworkTables should sync on startup, so one dashboard restart should be all you need. Are you using 1.0 or SFX?
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 01-02-2017, 08:59
rtrahms's Avatar
Rookie Year: 2013
We're using 1.0.
Yes, most single restarts get it, but I seem to recall sometimes needing two. It also seems more common than I am comfortable with.
Software Mentor
Unread 01-02-2017, 09:18
RufflesRidge RufflesRidge is offline
RufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant futureRufflesRidge has a brilliant future
Is this occurring on fresh starts of the Dashboard with the same Robot Code or are you seeing this when you modify the list of available options? If it's the latter, you may be running into https://github.com/wpilibsuite/SmartDashboard/issues/71
Unread 02-02-2017, 09:03
rtrahms's Avatar
Rookie Year: 2013
This is occurring on a fresh start of smart dashboard. I haven't made any changes to sendable chooser in a while.
Software Mentor
Unread 02-02-2017, 11:33
Oblarg Oblarg is offline
AKA: Eli Barnett
FRC #0449 (The Blair Robot Project)
Oblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond reputeOblarg has a reputation beyond repute
Yeah, SmartDashboard has never been particularly reliable. I wholly recommend physical switches for autonomous routine selection.
"Mmmmm, chain grease and aluminum shavings..."
"The breakfast of champions!"
Member, FRC Team 449: 2007-2010
Drive Mechanics Lead, FRC Team 449: 2009-2010
Alumnus/Technical Mentor, FRC Team 449: 2010-Present
Lead Technical Mentor, FRC Team 4464: 2012-2015
Technical Mentor, FRC Team 5830: 2015-2016
Unread 02-02-2017, 13:03
AustinShalit's Avatar
AustinShalit AustinShalit is offline
AKA: אוסטין
no team (WPILib Suite Developer)
AustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of lightAustinShalit is a glorious beacon of light
Improvements have been made this year to increase the reliability of the SmartDashboard. If you make a selection while the robot is disconnected, the SmartDashboard will send this selection to the robot when it connects.
There is an open PR right now to fix SendableChoosers not showing up:
https://github.com/wpilibsuite/SmartDashboard/pull/72
