Go to Post Throughout the "FIRST" experience we're all taught that if we try hard we'll achieve some level of success down the road; it hits everyone differently. - nlknauss [more]
Unread 01-02-2017, 18:32
drcooper drcooper is offline
FRC #6700
drcooper is an unknown quantity at this point
FRC Radio Configuration Utility won't start
Hey all,
New team here. We've got a chassis set up, control components laid out, RoboRIO flashed, and Eclipse/Java set up according to the instructions on the FIRST site. We've gotten to running the FRC Radio Configuration Utility in the instructions here, but having downloaded and installed the app, when we go to run it, it unceremoniously quits -- no windows coming up at all, just a brief spinning blue wheel then nothing.
We're running the system that came with the kickoff kit, so Lenovo netbook running Windows 10 Pro build 10586.753. Running out of ideas, so any suggestions would be most welcome!
Unread 01-02-2017, 18:43
5010Mentor 5010Mentor is offline
FRC #5010
5010Mentor is an unknown quantity at this point
Re: FRC Radio Configuration Utility won't start
Wonder if it is unable to locate Java. It is possible to configure Java within Eclipse but not have it recognized at command prompt.
If you type "java -version" within a command prompt, does it display anything?
Unread 01-02-2017, 19:19
Sky Captain's Avatar
Sky Captain Sky Captain is offline
Software Mentor and FIRST Volunteer
AKA: Will
FRC #0386 (Voltage)
Sky Captain is an unknown quantity at this point
Have you tried running the utility in administrator mode?
When in doubt, RTFM.
Unread 01-02-2017, 20:30
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
When it didn't launch for me, i restarted my computer. And the first thing i did once it finished starting up was running the configurator as administrator and it worked.
Team 3991: Driver since freshman (2015-), Captain since sophomore (2016-), CADer
"The human condition is not perfect. We are not perfect specimens, any of us. We're not robots." - Michael Ovitz
My posts may or may not reflect the views of my team, they are my opinions, and mine alone.
Unread 02-02-2017, 10:17
FRC #6700
Huh. It says "Error occurred during initialization of VM". Will try re-installing Java this morning. Thanks!
