Go to Post Students can learn to drive on whatever they give us. Ramps, carpet, grating, HDPE, lexan, diamond plate, regolith, other robots the driver station wall, referees, stairs, Dean, the bar, goals, the scorer's table, you name it, I've watched robots somehow manage to drive on it - Peter Matteson [more]
Unread 02-02-2017, 13:26
thejerishbrown's Avatar
thejerishbrown thejerishbrown is offline
FRC #0190 (Gompei and the Herd)
Rookie Year: 2013
thejerishbrown is an unknown quantity at this point
Setting PID constants in code for TalonSRX Velocity Control
I'm working with the CTRE Demo code for tuning closed-loop velocity control on the TalonSRX. When I set the PIDF constants in code (using _talon.setP, _talon.setI, etc), the values seem to not get set on the talon itself.
Here's what I'm seeing: When I run the code with any PID constants set, the system doesn't move whatsoever. No matter if I set any combination of P, I, D, or F, there is no response. If I go onto the roborio's web viewer (on http://roborio-<team>-frc.local) I can see the PID constants I set. If I manually re-enter and save the PID constants on the roborio web viewer, the system responds exactly as I would expect.
This only seems to be a problem when I set the control mode to TalonControlMode.Speed. I don't see the problem if I'm using TalonControlMode.Position. I've made sure all the firmware on the TalonSRXs, RoboRIO, and PDP are all up to date, as well as my wpilib and ctre lib installs.
