Go to Post Q&A is certainly a good route to take, but depending on how gray the topic in question is, CD is certainly a good place to ask the question. - slijin [more]
Unread 02-02-2017, 18:32
Maxcr1's Avatar
Maxcr1 Maxcr1 is offline
AKA: Max D
FRC #2169 (KING TeC)
Rookie Year: 2013
Maxcr1 is an unknown quantity at this point
Using PyNetworkTables with Java Configured RoboRio
So I have created some vision software for the Raspberry Pi, and I was planning on using PyNetworkTables to communicate the final values of the code on the Pi side over to the RoboRio side. The documentation on PyNetworkTables is unclear about compatibility with Java on the RoboRio, and I was wondering if any of you had any experience with it.
TL;DR: Is is possible to use PyNetworkTables to make a Raspberry Pi send values to a Java configured RoboRio?
Unread 02-02-2017, 19:52
SamCarlberg's Avatar
SamCarlberg SamCarlberg is offline
GRIP, WPILib. 2084 alum
FRC #2084
SamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to beholdSamCarlberg is a splendid one to behold
Re: Using PyNetworkTables with Java Configured RoboRio
NetworkTables doesn't know or care about how the values are getting read.
It's a bit like a website that doesn't care what browser you use. Chrome, Firefox, Opera, Safari, IE, it doesn't matter. Same for NetworkTables.
WPILib
GRIP, RobotBuilder
Unread 02-02-2017, 20:14
Maxcr1's Avatar
AKA: Max D
Rookie Year: 2013
This helps a lot. Thank you and good luck with the remainder of build season
