Go to Post to all of the people who are on robotics, I thank you for giving me the chance and happiness that i had never had before. robotics has been the happiest thing i have ever done in my life - gondorf [more]
Unread 02-02-2017, 21:41
darklink2458 darklink2458 is offline
FRC #4915 (Spartronics)
Rookie Year: 2015
darklink2458 is an unknown quantity at this point
Arduino Communication with Roborio
We have an arduino that runs the lights on our teams robot. We were wondering if there is a way to have the arduino react to commands made from the driver station. Thanks for any help you can provide.
Unread 02-02-2017, 21:47
elijah1111's Avatar
elijah1111 elijah1111 is online now
FRC #4601 (Circuit Birds)
Rookie Year: 2015
elijah1111 is an unknown quantity at this point
Re: Arduino Communication with Roborio
what do you mean by the driver station commands? what you could do you could use a pwm line or dio from the roborio to the ardouino and read it there
Unread 02-02-2017, 21:48
skidad68 skidad68 is offline
FRC #2506
Rookie Year: 2013
skidad68 is an unknown quantity at this point
You can have the Driver Station talk to the roboRIO, and then have the roboRIO talk to the Arduino using the serial port or I2C.
Unread 02-02-2017, 21:51
elijah1111's Avatar
Rookie Year: 2015
How complicated of lighting are we talking here? Would a simple PWM line or DIO not suffice. Just have the roborio output a PWM wave to the arduino to read then you could have your various lighting settings based on the PWM signals.
Unread 02-02-2017, 22:13
elijah1111's Avatar
Rookie Year: 2015
I would do something like this on arduino side, you could also have multiple pwm values for diffrent lights if you wanted it to.
Code:
float PWMsignal;//the signal from the roborio
void setup() {
  // put your setup code here, to run once:
PWMsignal=0;//intilizes signal
Serial.begin(9600);//syncs up serial output
void loop() {
  // put your main code here, to run repeatedly:
  PWMsignal=analogRead(3);//reads the pwm value for pin 3
  if(PWMsignal=42){//if its whatever pwm value you want turn pin 4 on
    digitalWrite(4,HIGH);
  else{
    digitalWrite(4,LOW);
Serial.println(PWMsignal);//outputs value to serial port
Unread 03-02-2017, 07:37
euhlmann's Avatar
euhlmann euhlmann is offline
CTO, Programmer
AKA: Erik Uhlmann
FRC #2877 (LigerBots)
Team Role: Leadership
Rookie Year: 2015
euhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud ofeuhlmann has much to be proud of
Originally Posted by elijah1111 View Post
Code:
float PWMsignal;
if(PWMsignal=42)
Creator of SmartDashboard.js, an extensible nodejs/webkit replacement for SmartDashboard
https://ligerbots.org
Unread 03-02-2017, 11:03
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
RyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond reputeRyanN has a reputation beyond repute
Originally Posted by euhlmann View Post
indeed
Code:
int PWMsignal;
if (PWMsignal == 42)
I would say that using that method would be highly susceptible to problems. You're relying on some undefined capacitance on the analog pin of the Arduino, cabling, and RoboRIO's PWM pins. You can use I2C, SPI, UART, or UDP/TCP if you get an Ethernet shield.
Another dead simple way would be to use some DIO as outputs. You can have 2^n modes where n is the number of outputs you use.
From Easy to Hard (my opinion of course):
DIO, UART, TCP/UDP, I2C
Taking a break from mentoring for a few years. (Is that allowed?!?)
Controls Mentor
@rnazaretian
Previous teams:
Team Fusion, FRC 364
Garnet Squadron, FRC 4901
