Go to Post Mountain Dew and Taco Bell. Nom Nom Nom. - R.C. [more]
Unread 03-02-2017, 13:05
YairZiv's Avatar
YairZiv YairZiv is offline
FRC #5951 (Makers Assemble)
Rookie Year: 2016
YairZiv is an unknown quantity at this point
Converting a iterative robot project to a command based project
Is it possible? We have programmed in iterative for this season and we're thinking about changing to command based. Is it possible to convert the same project to a command based without having to create a new one? Because creating a new one means that we'll need to open a new git and convert some other stuff like that.
If not then not problem but we'd rather use this project.
Unread 03-02-2017, 21:49
thecoopster20 thecoopster20 is offline
4th Year Programmer - Java
FRC #3602 (Robomos)
Rookie Year: 2014
thecoopster20 is an unknown quantity at this point
Re: Converting a iterative robot project to a command based project
While there isn't a magical converter tool, you can use the robot builder to generate the skeleton code for all of your subsystems, motors, and sensors.
Unread 04-02-2017, 05:10
YairZiv's Avatar
Rookie Year: 2016
Maybe I should have explained it a bit better
I want to use the code I have now, but will is work if I use subsystems and commands in the same way as if I created a Command Based project.
Unread 04-02-2017, 12:39
demosthenes2k8's Avatar
demosthenes2k8 demosthenes2k8 is offline
Graduated but not gone
AKA: Matt Soucy
FRC #0166 (Chop Shop 166)
Rookie Year: 2007
demosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to beholddemosthenes2k8 is a splendid one to behold
Send a message via AIM to demosthenes2k8 Send a message via Yahoo to demosthenes2k8
A command-based robot has specific `Robot.java` contents - the periodic functions call `Scheduler.getInstance().run();`, and the constructor creates instances of each subsystem. The other thing you'll need to make sure to examine is the `OI` class, to make sure that triggers are set up appropriately.
GSR Dean's List Finalist 2011
